OH NO - THE ENGINE I THINK, something went wrong |
johnpierre |
Sep 13 2018, 11:51 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hey everyone
thanks for the great info for the battery that i did end up buying. here is the back story. my car sat for about a year due to the fact it would not start. I just never got around to figuring out what the issue was (I thought it was a lot more involved that it actually ended up being) turns out it was just a dead battery. so i replaced it yesterday, and turned the key. took two or three turns but it fired up. sounded like crap. to be expected. it was on fumes so i putted to the gas station close by. never got the RPM's above 2000. got the gas, returned for home almost got back, then something in the engine bay broke, oil light came on, and it died. I did not want to try to start it again. pushed poor guy home, my lungs did not approve... the "break" sounded real "tin-can" like. thought maybe it might be due to no oil but i checked it this morning and there was plenty if not a bit dirty. anyways 2 ?'s #1 with what little info i have provided, did i do significant damage and #2 for all the LA/Culver City folk i need a trustworthy shop/mechanic |
nditiz1 |
Sep 13 2018, 11:56 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Raise one wheel, put it in 5th gear and see if you can turn the motor over by turning the raised wheel. This will tell if it died due to being locked up.
The oil light will come on as a result of the engine stopping due to no oil pressure. Unless you are saying the oil light came on and then after a few moments it died. |
johnpierre |
Sep 13 2018, 02:17 PM
Raise one wheel, put it in 5th gear and see if you can turn the motor over by turning the raised wheel. This will tell if it died due to being locked up. The oil light will come on as a result of the engine stopping due to no oil pressure. Unless you are saying the oil light came on and then after a few moments it died. green light came on as it died not after - sounds like that is a good sign... |
Lo-Fi Version | Time is now: 6th June 2024 - 08:21 AM |
