LE 15322, It will be six years in November |
rstover |
Sep 11 2018, 04:39 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
I was not going to start thread until the car was home, but it is getting close and I want to share some pictures of the car and the progress.
IMG_2173.mov ( 3.24mb ) Number of downloads: 1033 |
914_7T3 |
Sep 11 2018, 05:18 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well?
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
rstover |
Sep 12 2018, 04:59 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
914_7T3 |
Sep 13 2018, 03:51 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint. There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was. I know exactly what you mean! |
rstover |
Sep 13 2018, 05:55 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint. There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was. I know exactly what you mean! The pad on the flat part looks familiar. What kind of material do you think it is? |
Lo-Fi Version | Time is now: 4th June 2024 - 08:06 PM |
