| ctc911ctc |
Sep 14 2018, 03:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Hi,
Have been spending a great amount of time on timing. Bought new everything (points, wires, coil, etc). set the gap to .016 as per the manual and then the dwell came in at 25. closed the gap more and cannot get the dwell above 40 (aiming at 45). Right now it is at 39. Question: what would you chase first? Points? (perhaps they are not engineered correctly) (they are not Bosch) Dwell Meter ( I have 2 of the same manufacturer - I know, I know.....) Ignition Cam? (car has 20K on it, should be ok) Ignore the last 6-8 dwell points and go to the next thing (close enough) Thank |
TheCabinetmaker Do you have the meter set to 4cyl? Sep 14 2018, 04:11 PM
Spoke My comment won't help you set the points corre... Sep 14 2018, 07:30 PM
ctc911ctc Thanks - will pursue the points - going for 100% f... Sep 15 2018, 05:14 PM
Jeff Hail Did you disconnect and plug the vacuum line?
Krus... Sep 14 2018, 08:53 PM
ctc911ctc Jeff,
Funny you sent this, I read this thread pri... Sep 15 2018, 05:13 PM
r_towle Pull the distributor, set the points on the bench?... Sep 16 2018, 09:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 01:28 AM |
