Bodyguys, Where do you get your sandpaper?, What do you use? |
Andyrew |
Mar 8 2011, 12:08 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I bought some high quality sandpaper a long time ago from a swap meet for pretty cheap, turns out that it was some pretty good stuff. Now I am pretty low on a couple of grits and I was wondering where I should pick some up from. I know there are a lot of different brands and high and low quality stuff, and have read a couple of old threads on other forums but im curious what you guys use and where do you get it.
Thanks all! Andrew |
914forme |
Sep 14 2018, 04:56 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif)
Andyrew |
Sep 14 2018, 05:10 PM
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif) I find sandpaper gums up much quicker than it wears. I would typically keep a wire brush next to me and once the paper was mostly loaded I would brush it real quick.. But there would be stuck gummy spots that wouldnt come off, after a while the paper is not reliably flat. This is when I would replace it. I typically have a separate sandpaper board specifically for knocking initial filler or primer down as thats the stickiest. With how good current sandpaper is, I dont think its worth the cost for anyone other than a pro shop. |
worn |
Sep 14 2018, 06:24 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif) I find sandpaper gums up much quicker than it wears. I would typically keep a wire brush next to me and once the paper was mostly loaded I would brush it real quick.. But there would be stuck gummy spots that wouldnt come off, after a while the paper is not reliably flat. This is when I would replace it. I typically have a separate sandpaper board specifically for knocking initial filler or primer down as thats the stickiest. With how good current sandpaper is, I dont think its worth the cost for anyone other than a pro shop. I can clog it just fine. But sand paper can lose the cutting edge real fast sometimes. In my experience you can feel the edge. My spare time is free, but using worn out paper gets me impatient. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:57 AM |
