> 1974 2.0 Won’t start Help!
gtsilver16
post Sep 15 2018, 12:54 AM
Hi, I’m a newbie 914 owner and inept at mechanical repair. My 74 2.0 won’t start. I’ve had it several months and it always starts fine, albeit it cranks 4-5 time before catching normally. This evening I was cleaning the engine bay with Simple Green and a tooth brush and afterwards it wouldn’t start. It turns over strong but doesn’t catch. I could’ve disconnected something while thrashing around in the cramped engine bay while cleaning? The vacuum hoses are intact, I know that because I just replaced all of them. When I turn the key to position 1, I don’t hear anything (I think you’re supposed to hear the fuel pump). There is gas in the car.
Any thoughts on trouble shooting? I don’t think I could’ve sprayed enough Simple Green to have flooded the plugs, distributor etc. I was cleaning around the hole in the cyl 3/4 head (where the anti flashback hose connects) so some amount of cleaner did go into the head but I’m talking like a teaspoon.
Thanks for helping, I’m really clueless. I’m in San Francisco if anyone can refer and honest 914 mechanic.
JawjaPorsche
post Sep 15 2018, 03:07 AM
Again, check your connections. Check your fuses too. There is one in your relay cover too so check that one too. I thought my fuel pump was fried but it was the fuse under the relay cover.
gtsilver16
post Sep 15 2018, 08:29 AM
QUOTE(JawjaPorsche @ Sep 15 2018, 04:07 AM) *
Thanks I’ll check the fuses. When you say “ connections” what are you referring to?
- Lo-Fi Version Time is now: 2nd July 2025 - 11:03 PM
