> Tachometer rebuild
totle
post Sep 13 2018, 06:27 AM
Region Association: Europe
Hi,
Anyone that have a DIY description of how to rebuild a 7k Tach to a 10k Tach ?
and from 4 cyl to 6.
I would think that there is someone who has done this.
Any potmeter adjustments, og parts that needs to be replaced ?
I know that NHS does this, but would be nice to do it and just buy a new faceplate
timothy_nd28
post Sep 17 2018, 08:59 AM
The Ashlock tach-adapt is the wrong product for what is trying to be done here. The tach-adapt will not re-scale our existing tach to a 10k faceplate. With that said, he does have a product for sale called a "tach-drive module" which is made for re-scaling and could be a good option. Since Ashlock's tach drive replaces all the electrical guts in our existing tach, it still needs to reuse the original movement, so there will still be some needle bounce.
My idea is the same principle as Ashlock's tach-drive module, but you get a new air core motor that replaces the old spring mass movement. New electronics and a new modern style servo motor equals no needle bounce.
Here's my write up: http://www.914world.com/bbs2/index.php?showtopic=216719
So to reinstate the question that was originally asked, can you take a stock 914 tachometer and convert it into a 10k tachometer?
Yes, and there are some company's out there that will gladly do this for you. NHS will take your existing tachometer and convert it for you for upwards of 600 dollars. I think the better question would be "can you convert a stock 914 tachometer to a 10K tachometer for under 100 dollars"?
Either Ashlock's module or my conversion method will have you covered in the electronics department. The new artwork for the face dial is the real issue IMO. It may be worth buying this premade 10k face dial and doing this conversion. But this dial is overseas and might break the 100 dollar budget limit.
Retroracer
post Sep 17 2018, 12:33 PM
"can you convert a stock 914 tachometer to a 10K tachometer for under 100 dollars"? is a great question!
Found this thread intriguing; I'm up for trying this with a -4 tach, Tim's updated tach innards (excellent R and D around this Tim, nice work!) and a replacement / hacked 10K face. The German one is a bit pricey but not too bad, noting that the "VDO" label is not present, presumably for legal reasons. I'll investigate the Aussie alternative (thanks Porschetub).
Already stripped the -4 tach, will post progress if anyone has interest. This will be used with a -6 engine running MSD Strassefeuer ignition for the tach output.
- Tony
totle   Tachometer rebuild   Sep 13 2018, 06:27 AM
timothy_nd28   I have toyed with the idea of doing just this, but...   Sep 13 2018, 06:51 AM
timothy_nd28   Trond from Norway has pointed out to me that these...   Sep 13 2018, 08:31 AM
peteyd   I would be interested in this. Could you perhaps ...   Sep 13 2018, 11:00 AM
timothy_nd28   The tach drive that I spec'd out in my DIY thr...   Sep 13 2018, 11:26 AM
totle   Thanks for sharing the information Timothy Great D...   Sep 13 2018, 04:13 PM
mepstein   I forgot I have a 10K tach. :D   Sep 14 2018, 05:56 PM
Mark Henry   An Ashlock tachadapt will turn a /4 tach into a /6...   Sep 14 2018, 06:29 PM
PlaysWithCars   Tach bounce. Now there is something that I would...   Sep 15 2018, 09:57 AM
nickg   Tach bounce. Now there is something that I woul...   Sep 17 2018, 04:42 PM
Spoke   [quote name='PlaysWithCars' post='2649065' date='...   Sep 18 2018, 05:22 AM
porschetub   Howard Instruments in Victoria ,Australia do a 10K...   Sep 15 2018, 03:15 PM
timothy_nd28   The Ashlock tach-adapt is the wrong product for wh...   Sep 17 2018, 08:59 AM
Retroracer   "can you convert a stock 914 tachometer to a ...   Sep 17 2018, 12:33 PM
mepstein   Only problem I see with a 10k tach face on a 4 is ...   Sep 17 2018, 12:47 PM
Retroracer   Only problem I see with a 10k tach face on a 4 is...   Sep 17 2018, 01:43 PM
timothy_nd28   Mark brings up a good point. Not many engines rev...   Sep 17 2018, 01:29 PM
Spoke   Can a 911 tach be substituted? Don't know if t...   Sep 17 2018, 01:29 PM
timothy_nd28   911 and 914 tach sizes are identical   Sep 17 2018, 01:31 PM
mepstein   These just showed up today. I always wanted a set ...   Sep 17 2018, 02:25 PM
jrblackbox   These just showed up today. I always wanted a set...   Sep 17 2018, 03:42 PM
mepstein   These just showed up today. I always wanted a se...   Sep 17 2018, 08:38 PM
Larmo63   I don't get the 'need' for a 10,000 RP...   Sep 17 2018, 11:33 PM
totle   Great looking cars Lawrence :-) 10k is not needed...   Sep 18 2018, 03:27 AM
914forme   You all make me :rotfl: I tried to stay out of th...   Sep 18 2018, 07:27 AM
timothy_nd28   Sounds like Stephen is all in with this project, w...   Sep 18 2018, 09:06 AM
914forme   Yes you use an opaque poly sheet with a matte blac...   Sep 18 2018, 06:32 PM
timothy_nd28   I was totally kidding, this project is cool but no...   Sep 18 2018, 07:44 PM
stownsen914   I didn't read through the whole thread, but in...   Sep 18 2018, 08:11 PM
mepstein   I didn't read through the whole thread, but i...   Sep 18 2018, 08:41 PM
914forme   I just picked up a bunch of various tacos to give ...   Sep 18 2018, 07:57 PM
914forme   Maybe it is not hard to draw up with a vector soft...   Sep 18 2018, 08:22 PM
mepstein   Maybe it is not hard to draw up with a vector sof...   Sep 18 2018, 08:42 PM
914forme   It is also not clocked, which I prefer to do on a ...   Sep 18 2018, 08:25 PM
914forme   Never knew that, thanks Mark   Sep 19 2018, 06:10 AM
mepstein   Never knew that, thanks Mark Now the tach on the...   Sep 19 2018, 06:28 AM
914forme   Duplicate Post   Sep 19 2018, 06:10 AM
mepstein   10k tach for sale on the bird. http://forums.pel...   Sep 22 2018, 11:04 AM
- Lo-Fi Version Time is now: 3rd March 2026 - 04:58 AM
