> Stumped, motor won't fire on #1
Rusty
post Sep 17 2018, 04:25 PM
We're stumped. I even caved and took it to my local VW expert for help.
Background: The car had been stored for 7-8 years. Before storage, it had been worked on by a third party (including replacing the distrubutor, IIRC). When the car was stored, it was running poorly.
Symptom: Car won't fire on cylinder #1, but fires fine on 2 thru 4. (Was it firing on #1 prior to storage... I dunno. I stored it out of frustration.)
Motor: 1973 1.7L, dual Weber carbs, Pertronix points replacement in 009 distributor.
Details: Car has air, fuel, and spark.
Air: Valves are adjusted correctly (.006) and timing is on. Compression on all cylinders is 90-95 pounds. Heat exchanger removed and checked for obstruction. Covering/blocking the air intake on #1 has no effect to the motor running.
Fuel: Carb on cylinders 1/2 has been cleaned and adjusted. We can watch fuel go into the cylinder. Some of it ends up as white smoke going out the exhaust. There is an oil leak on the drivers side of the motor and the oil smells faintly of fuel.
Spark: Plug wires are routed correctly. Taking a plug out and laying it on engine tin, spark is strong. Wires, cap, rotor, and plugs have all been swapped out. Pulling the plug wire on #1 at any RPM results in no change.
I talked to my guy today... he's very well regarded in the area. He's as stumped as I am.
Any thoughts?
iankarr
post Sep 17 2018, 05:55 PM
Depending on the linkage, swapping the full carb from one side to the other could be a big deal. I'd def start with the jet stacks on the same side. It shouldn't take more than a couple minutes to switch 1 to 2. Hopefully the problem will follow and all that will be needed is a good jet cleaning.
Rusty   Stumped   Sep 17 2018, 04:25 PM
nickg   check to see if the cap is secure on the distribut...   Sep 17 2018, 05:00 PM
Rand   check to see if the cap is secure on the distribu...   Sep 17 2018, 05:04 PM
rudedude   Did you test the plug from that cylinder for spark...   Sep 17 2018, 05:15 PM
Rand   Did you read his post? Not trying to sound krusty,...   Sep 17 2018, 05:19 PM
Rusty   check to see if the cap is secure on the distribu...   Sep 17 2018, 05:26 PM
cuddy_k   maybe the fuel isn't fully atomizing? Try swit...   Sep 17 2018, 05:40 PM
Rand   I like Ian's thinking. Fuel has to be the high...   Sep 17 2018, 05:44 PM
worn   I like Ian's thinking. Fuel has to be the hig...   Sep 17 2018, 05:51 PM
cuddy_k   Depending on the linkage, swapping the full carb f...   Sep 17 2018, 05:55 PM
Chris914n6   intake valve not opening, bent pushrod or somethin...   Sep 17 2018, 05:58 PM
Rand   intake valve not opening, bent pushrod or somethi...   Sep 17 2018, 06:03 PM
michael7810   Also check the idle jets and mixture screw port fo...   Sep 17 2018, 06:00 PM
flyer86d   Weber carbs run on the idle circuit about half way...   Sep 17 2018, 06:08 PM
VaccaRabite   Dirty plug? Pull the plug and wire wheel off the ...   Sep 17 2018, 07:34 PM
Rusty   I do appreciate all the replies. I'm taking n...   Sep 17 2018, 07:50 PM
Spoke   Have you checked the airflow into each cylinder us...   Sep 18 2018, 08:17 AM
struckn   I'm know expert but I had a similar condition ...   Sep 18 2018, 08:54 AM
IronHillRestorations   I too suspect a fuel delivery problem for that bar...   Sep 18 2018, 11:29 AM
wndsrfr   I too suspect a fuel delivery problem for that ba...   Sep 18 2018, 12:20 PM
7TPorsh   Vacuum leak on the intake top or base? I would tr...   Sep 18 2018, 12:02 PM
John   If it's always cyl#1, at least you have narrow...   Sep 18 2018, 12:49 PM
jvmarino   Maybe try swapping #1 plug with another cylinder p...   Sep 18 2018, 01:06 PM
Rusty   I picked up the car today and discussed some of th...   Sep 18 2018, 04:26 PM
cuddy_k   Have you checked the airflow into each cylinder u...   Sep 18 2018, 04:49 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 06:31 AM
