> Stumped, motor won't fire on #1
Rusty
post Sep 17 2018, 04:25 PM
We're stumped. I even caved and took it to my local VW expert for help.
Background: The car had been stored for 7-8 years. Before storage, it had been worked on by a third party (including replacing the distrubutor, IIRC). When the car was stored, it was running poorly.
Symptom: Car won't fire on cylinder #1, but fires fine on 2 thru 4. (Was it firing on #1 prior to storage... I dunno. I stored it out of frustration.)
Motor: 1973 1.7L, dual Weber carbs, Pertronix points replacement in 009 distributor.
Details: Car has air, fuel, and spark.
Air: Valves are adjusted correctly (.006) and timing is on. Compression on all cylinders is 90-95 pounds. Heat exchanger removed and checked for obstruction. Covering/blocking the air intake on #1 has no effect to the motor running.
Fuel: Carb on cylinders 1/2 has been cleaned and adjusted. We can watch fuel go into the cylinder. Some of it ends up as white smoke going out the exhaust. There is an oil leak on the drivers side of the motor and the oil smells faintly of fuel.
Spark: Plug wires are routed correctly. Taking a plug out and laying it on engine tin, spark is strong. Wires, cap, rotor, and plugs have all been swapped out. Pulling the plug wire on #1 at any RPM results in no change.
I talked to my guy today... he's very well regarded in the area. He's as stumped as I am.
Any thoughts?
Rusty
post Sep 18 2018, 04:26 PM
I picked up the car today and discussed some of the above theories with my mechanic. He's very gracious and only charged me for a fraction of the time he has in the car.
We talked about cleaning the carb (he tore it all the way down & cleaned) and also swapping the jet stacks (also tried). I think these potential solutions can be ruled out.
QUOTE(Spoke @ Sep 18 2018, 08:17 AM) *
Have you checked the airflow into each cylinder using a sync meter? This will let you know that each cylinder is pulling the same volume of air. Even by putting your hand over the opening of the carb you should be able to feel the vacuum.
Yes. In kg/hr on my meter at approx 1000 rpm idle: #1 - 6, #2 - 8, #3 - 7, #4 - 7.
QUOTE(struckn @ Sep 18 2018, 08:54 AM) *
I'm know expert but I had a similar condition that turned out to be a dropped a Valve Seat?
Also, was a Cam for Carburetor conversion from FI made. Might cause for a rough running engine condition. Did it run right before you put it in storage?
Damn, I hope it's not a dropped valve. It doesn't sound like that to me.
I have no idea what cam is in the engine. It's not the original engine to the car, so it's anyone's guess. It ran well for me at one time - I'll leave it at that.
QUOTE(IronHillRestorations @ Sep 18 2018, 11:29 AM) *
I too suspect a fuel delivery problem for that barrel. Look down the throat of #1 carb barrel, you should see fuel squirting when you open the throttle enough to actuate the accel pump. Spraying some fuel down the barrel (with spray bottle in a leather gloved hand, and fire extinguisher within reach) will tell you if you have a fuel delivery problem.
Could also be a valve problem, if so, probably intake, such as stuck valve, bad rocker arm, bad lobe on cam. This could be seen by taking off the valve cover and turning the engine.
First thing I'd do is warm it up and block the throttle at about 1800 rpm's and squirt some fuel down #1 barrel. Just be really careful. In theory you could use ether, but that's not good on your engine.
You can look down the carb and see fuel squirting.
My guy tried both fuel and ether. With the exchanger removed, he sprayed fuel directly up into the chamber trying to get something to ignite.
I'm starting to wonder if the cylinder has too much fuel or isn't mixing well enough with the air.
QUOTE(John @ Sep 18 2018, 12:49 PM) *
If it's always cyl#1, at least you have narrowed it down some.
If compression is good, it can only be fuel or ignition. If the plug fires when grounded to the tin, it's a good sign, but harder to test once installed in the engine.
I test them using the magnetic pick-up of a strobe type timing light or an inductive spark checker along the plug wire (the in-line spark checkers would accomplish the same thing). That insures that the circuit is complete and the plug has a decent ground. If spark is good it really points toward fuel. If it does not spark when the plug is screwed into the head, it may not be grounded well or at all, or could be a bad plug.
Test one thing at a time and you will figure it out.
Thanks for the encouragement, man. (IMG:style_emoticons/default/smile.gif)
QUOTE(jvmarino @ Sep 18 2018, 01:06 PM) *
Maybe try swapping #1 plug with another cylinder plug. See if problem moves with the plug.
Good idea. When this was done, the issue stayed with cylinder, not the plug or plug wire.
The leak at the head cylinder mating surface of #1 is unusual to me. The oil leaking there smells like fuel. I'd think that area was compromised except the compression came out to 90 pounds on #1.
Strange indeed. I'll be able to piddle with it in the evenings a bit.
Appreciate all the commentary. I've got a lot to think about and I need to do it methodically.
iankarr
post Sep 18 2018, 04:49 PM
Interesting that the side with the unequal readings is the one with the issue. I had a very similar condition on my carb car (only in my case it was #2 that didn't seem to be firing) and once I got the airflow dialed in and equal, the problem went away. I wonder if adjusting the air mixture screw on #1 (and balancing the stacks) might bring #1 back to life. It's also possible that the higher vacuum on #2 is somehow stealing juice from its neighbor.
Rusty   Stumped   Sep 17 2018, 04:25 PM
nickg   check to see if the cap is secure on the distribut...   Sep 17 2018, 05:00 PM
Rand   check to see if the cap is secure on the distribu...   Sep 17 2018, 05:04 PM
rudedude   Did you test the plug from that cylinder for spark...   Sep 17 2018, 05:15 PM
Rand   Did you read his post? Not trying to sound krusty,...   Sep 17 2018, 05:19 PM
Rusty   check to see if the cap is secure on the distribu...   Sep 17 2018, 05:26 PM
cuddy_k   maybe the fuel isn't fully atomizing? Try swit...   Sep 17 2018, 05:40 PM
Rand   I like Ian's thinking. Fuel has to be the high...   Sep 17 2018, 05:44 PM
worn   I like Ian's thinking. Fuel has to be the hig...   Sep 17 2018, 05:51 PM
cuddy_k   Depending on the linkage, swapping the full carb f...   Sep 17 2018, 05:55 PM
Chris914n6   intake valve not opening, bent pushrod or somethin...   Sep 17 2018, 05:58 PM
Rand   intake valve not opening, bent pushrod or somethi...   Sep 17 2018, 06:03 PM
michael7810   Also check the idle jets and mixture screw port fo...   Sep 17 2018, 06:00 PM
flyer86d   Weber carbs run on the idle circuit about half way...   Sep 17 2018, 06:08 PM
VaccaRabite   Dirty plug? Pull the plug and wire wheel off the ...   Sep 17 2018, 07:34 PM
Rusty   I do appreciate all the replies. I'm taking n...   Sep 17 2018, 07:50 PM
Spoke   Have you checked the airflow into each cylinder us...   Sep 18 2018, 08:17 AM
struckn   I'm know expert but I had a similar condition ...   Sep 18 2018, 08:54 AM
IronHillRestorations   I too suspect a fuel delivery problem for that bar...   Sep 18 2018, 11:29 AM
wndsrfr   I too suspect a fuel delivery problem for that ba...   Sep 18 2018, 12:20 PM
7TPorsh   Vacuum leak on the intake top or base? I would tr...   Sep 18 2018, 12:02 PM
John   If it's always cyl#1, at least you have narrow...   Sep 18 2018, 12:49 PM
jvmarino   Maybe try swapping #1 plug with another cylinder p...   Sep 18 2018, 01:06 PM
Rusty   I picked up the car today and discussed some of th...   Sep 18 2018, 04:26 PM
cuddy_k   Have you checked the airflow into each cylinder u...   Sep 18 2018, 04:49 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 06:31 AM
