Friday, 19 September 2025
> 1st Gear Difficult to Engage
jkb944t
post Sep 17 2018, 11:12 AM
I have had a problem with engaging 1st gear ever since I have had this 914. I have already done all the bushings and rebuilt the transmission. I can easily engage all the other gears including reverse.
I really have to pull hard to the left and down to actually engage 1st gear. It feels like a linkage issue but reverse is very easy to engage so I am not sure that is the case.
Does this just sound like a basic linkage adjustment issue? Any thoughts or ideas would be appreciated.
Jeff B
jkb944t
post Sep 19 2018, 05:58 AM
Wow, what a wealth of information! Thanks! (IMG:style_emoticons/default/piratenanner.gif)
I already reinforced the clutch tube so I sure hope it is still good but I will check. Since reverse is very easily engaged I think that would rule out the clutch since it would affect both 1st and reverse.
To clarify, when I engage 1st it never grinds it just binds (like it is blocked) if I don't pull very hard to the left and pull down hard on the shifter. This most likely does point to a shifter adjustment although I thought I did it right.
Jeff B
djway
post Sep 19 2018, 10:13 AM
QUOTE(jkb944t @ Sep 19 2018, 04:58 AM) *
Jeff B
One clue as to the cause either being the transmission or the clutch cable tube system would be, how far off the floor does the clutch pedal rise before the club starts to engage?
jkb944t
post Sep 19 2018, 12:45 PM
QUOTE(djway @ Sep 19 2018, 12:13 PM) *
Jeff B
I believe that it engages fairly high like shown on Dr. Evil's very helpful trouble shooting info. I will certainly verify it this weekend.
Jeff B
djway
post Sep 19 2018, 02:21 PM
QUOTE(jkb944t @ Sep 19 2018, 11:45 AM) *
Jeff B
If that is the case then next recheck your linkage and adjustment if that’s not it…
Jeff B
jkb944t   1st Gear Difficult to Engage   Sep 17 2018, 11:12 AM
toolguy   If you are still rolling a little, does it go in 1...   Sep 17 2018, 12:14 PM
jkb944t   If you are still rolling a little, does it go in ...   Sep 17 2018, 08:41 PM
dr914@autoatlanta.com   the 901 style gearbox is notorious of being hard t...   Sep 17 2018, 01:14 PM
gereed75   one last suggestion - You may be hitting the end o...   Sep 17 2018, 01:29 PM
jkb944t   one last suggestion - You may be hitting the end ...   Sep 17 2018, 08:44 PM
burton73   If the car is in neutral, I always put the car in ...   Sep 17 2018, 02:42 PM
pete000   Both my 914s are fussy going into first when stopp...   Sep 17 2018, 02:51 PM
djway   I have owned many an aircooled that had this probl...   Sep 17 2018, 09:08 PM
Lucky9146   I have had a problem with engaging 1st gear ever ...   Sep 17 2018, 10:46 PM
Dr Evil   Man I chase this issue for customers, often. On ra...   Sep 18 2018, 08:56 AM
Dr Evil   Some further internal mechanics to consider that c...   Sep 18 2018, 09:05 AM
914Toy   Some further internal mechanics to consider that ...   Sep 18 2018, 01:58 PM
VaccaRabite   Usually going into first is not an issue for me. L...   Sep 18 2018, 10:55 AM
Dr Evil   Usually going into first is not an issue for me. ...   Sep 18 2018, 11:20 AM
914Toy   Hmmm - my message did not attach? Will send again...   Sep 18 2018, 01:59 PM
914Toy   Does the passage of time and miles reduce this ban...   Sep 18 2018, 02:03 PM
jkb944t   Wow, what a wealth of information! Thanks...   Sep 19 2018, 05:58 AM
djway   Wow, what a wealth of information! Thanks...   Sep 19 2018, 10:13 AM
Dr Evil   Wow, what a wealth of information! Thanks...   Sep 19 2018, 11:05 AM
jkb944t   Wow, what a wealth of information! Thanks...   Sep 19 2018, 12:45 PM
djway   [quote name='djway' post='2650188' date='Sep 19 2...   Sep 19 2018, 02:21 PM
jkb944t   I didn’t have too much time this weekend to work...   Sep 24 2018, 10:42 AM
- Lo-Fi Version Time is now: 19th September 2025 - 02:06 PM
