Auxiliary oil cooler, An alternate location |
IronHillRestorations |
Sep 21 2018, 07:25 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
25 years ago when I put a 3.0 SC engine in my 914, I understood the need for additional oil cooling, but I didn’t want to cut up my frunk, or run 26 feet of oil lines. My car was a street hot rod, and really didn’t plan on doing track events, so I didn’t need the maximum possible oil cooling.
My solution back then was to put a 25 row Mocal cooler with a fan sandwiched on it in front of the right rear wheel, on the opposite side of the car from the oil tank. This worked out well, and neither I or the current owner has seen oil temps out of range. I have another street hod rod in the works and since the right rear quarter panel was removed for rust repair, I decided to revisit this alternate oil cooler location. After measuring, mocking up, and some head scratching I figured a 34 row 234 matrix Mocal cooler would fit. Here’s what I’ve come up with. To test fit a Spal puller fan, I taped it to the cooler. Two holes drilled for the front bracket and one weld nut for the rear bracket. 3 M8 cap screws are more than enough to secure the cooler |
Steve |
Sep 21 2018, 05:27 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area.
Sep 21 2018, 07:13 PM
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area. I'm considering making custom rockers and ducting up to that area, but we may hold off and see how it does. That cooler is about 1/3 larger in size and capacity than the kit BAT makes to replace a 911 front fender cooler. The engine will be totally rebuilt by a master engine builder, and a new tight engine will always run cooler than an older engine with more blow by. |
rgalla9146 |
Sep 21 2018, 10:14 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area. I'm considering making custom rockers and ducting up to that area, but we may hold off and see how it does. That cooler is about 1/3 larger in size and capacity than the kit BAT makes to replace a 911 front fender cooler. The engine will be totally rebuilt by a master engine builder, and a new tight engine will always run cooler than an older engine with more blow by. Hey Perry Nice installation. Great use of overlooked space. I'm planning on putting an AC condenser there. I'll provide airlflow by adding a fan and louvers or some form of opening in the fender. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:30 PM |
