Help hooking up engine bay heater fan |
Cool914 |
Sep 24 2018, 09:18 AM
Member Group: Members Posts: 98 Joined: 25-January 11 From: Ontario Member No.: 12,627 Region Association: Canada |
Trying to figure out how to connect my heater fan to the harness. There are 2 wires from the harness, 2 on the fan, and a ground wire in the area that has one of the female and male connectors. Tthe fan and harness wires all have female spade. It is a 71 1.7. Not the best pic but you get the idea.
Help. Need heat soon. Actually just trying to get it safetied and need heat. Greg |
dr914@autoatlanta.com |
Sep 24 2018, 10:00 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the two wires from the fan itself usually green for the positive and brown for the negative, plug into the ignition wiring harness to the corresponding wires in an H connector. Positive sometimes is a yellow. if your ignition harness does not have this extra dual wire loom then you may have a 73-76 ignition harness installed on your engine
Trying to figure out how to connect my heater fan to the harness. There are 2 wires from the harness, 2 on the fan, and a ground wire in the area that has one of the female and male connectors. Tthe fan and harness wires all have female spade. It is a 71 1.7. Not the best pic but you get the idea. Help. Need heat soon. Actually just trying to get it safetied and need heat. Greg |
Lo-Fi Version | Time is now: 9th June 2024 - 05:22 PM |
