The right way to close up a welding project, Primer? Weld Through? Weld putty? POR15? |
ctc911ctc |
Sep 26 2018, 05:41 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
I am looking for definitive guidance and perhaps a pointer to a thread on this topic. We have finished all of the welding on metal that was primed with weld-through. We will now grind the welds. Is this the correct thing to do in this order? Zinc Primer Weld Weld some more plug up the holes with weld or epoxy (screw holes and small gaps) Grind the weld and expoy smooth (smoother) Treat the welds with 3M weld putty spray another coat of Primer Coat with POR15 Do I have this right? Flame ON!!!! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) |
bbrock |
Sep 28 2018, 07:41 PM
I just came inside from treating all the internals on my bare tub with Ospho/phosporic acid (I'm actually using Klean-Strip brand because it is cheaper and more readily available). I'm also a vote for rust converter but am using a belts and suspenders and another belt approach. All internal frame members get a phosphoric acid treatment followed by Eastwood Internal Frame Coating which is a rust encapsulator, which will be followed by cavity wax which is another rust encapsulator that I've had very good experience with. My understanding is that a rust encapsulator simply seals the rusted area off from oxygen so the oxidation process is halted. That means the encapsulator works only as long as it provides that perfect seal from oxygen. So I think it makes sense to get rid of as much rust as possible either through removal or chemical conversion first.
For the rest of my metal work, the process I've decided on is to:
Lo-Fi Version | Time is now: 11th June 2024 - 07:11 PM |
