| 914Toy |
Oct 5 2018, 10:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
I recently installed a "double" Innovative air/fuel (A/F) gauge with sensors in both headers of my 1977 2.7 911 engine, which is stock except for: ignition, Weber carbs, reground cams (modified SC) for spirited street performance with the carbs, and exhaust headers (MB911). The A/F gauge has assisted final tuning, including fine balancing of the carbs (well worth it).
Ignition is Clewett crank fire with ignition timing set at: 10 deg. idle 800 rpm, 29 deg at 3000 rpm, and 33 deg at 6000rpm. Carbs are Weber 40IDA's with 34 main chokes and tall secondary chokes. Jets are: 145 main's, 180 air correction's, F3 emulsion tubes, and 60 idle's. Engine is running very smoothly at all rpm's, no carb "spitting" or exhaust popping, no hesitation under any acceleration, and instant accelerator response with plenty of power. In other words, running great. However, A/F's are not perfect with 10.5 at idle, 12.5 to 13 at cruising, and high 13's up hill WOT. On a recent uninterrupted 180 miles run on 101 at 3400rpm (78mph), fuel consumption was 24miles per gallon (IMG:style_emoticons/default/smile.gif) I have discussed the A/F ratio issue with several carb "experts" - mostly Old School guys. Consensus is my numbers are as good as it gets vs. near perfect 14.7 A/F one can expect from EFI. Any comments will be welcome. |
| 914Toy |
Oct 11 2018, 12:43 PM
After further research and inspection of the carbs, it seems logical to me, as suggested by some on PP, that the idle air jets are too small, as there is almost no change in A/F's when reducing the idle jets from 60's to 55's, which is actually a significant reduction in jet cross sectional area, about 14%. Thus I am considering drilling these air jets out a little as some others have done. The air jet holes are close to 1.3mm in diameter. What increase in diameter does anyone suggest?
| 72hardtop |
Oct 11 2018, 03:40 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
After further research and inspection of the carbs, it seems logical to me, as suggested by some on PP, that the idle air jets are too small, as there is almost no change in A/F's when reducing the idle jets from 60's to 55's, which is actually a significant reduction in jet cross sectional area, about 14%. Thus I am considering drilling these air jets out a little as some others have done. The air jet holes are close to 1.3mm in diameter. What increase in diameter does anyone suggest? I'm against reaming jets. No matter how careful one is it never seems to work out well in the end. Your idle jet meters A/F during the progression phase. The mixture screws only adjust the A/F mixture when idling. No other time. Bigger air corrector brings mains in sooner smaller delays the mains. Best to pull the whole stack and drive with only the idle jets. You'll know exactly when it fall on it's face. Be conservative with the accel pump adjustment during this time. The graphs you posted to are a bit incorrect. The first graph say fuel enters main jet into idle circuit. That is incorrect. It enters the idle jet circuit. The main jet does not meter fuel for the idle jet or circuit. On IDF's the air entering the idle circuit flows in from the idle air bleed ports not idle air correction jets as the graph refers to. The main jet on IDF's is at the end of the emulsion tube. |
914Toy Jetting Webers on 2.7 911 engine. Oct 5 2018, 10:52 AM
gereed75 Agree with "experts". Those A/F's ... Oct 5 2018, 02:09 PM
TravisNeff Is this an S spec engine, or standard? (35mm ports... Oct 5 2018, 02:46 PM
914Toy
Is this an S spec engine, or standard? (35mm port... Oct 5 2018, 04:53 PM
TravisNeff I got a vent and jet kit from PartsKlassic, they s... Oct 5 2018, 04:59 PM
PanelBilly Sounds like you’ve found a sweet spot. I’ve be... Oct 6 2018, 07:36 AM
larryM see jetting chart here
http://forums.pelicanpart... Oct 6 2018, 11:18 AM
914Toy
http://forums.pelicanpar... Oct 6 2018, 01:10 PM
IronHillRestorations You can lean it out a bit by just opening the air ... Oct 6 2018, 08:11 PM
porschetub
You can lean it out a bit by just opening the air... Oct 7 2018, 12:38 AM
larryM more info
check this site - Mike Pierce is ... Oct 6 2018, 10:25 PM
GeorgeRud Paul Abbot’s Performance Oriented site also has ... Oct 7 2018, 07:11 AM
gereed75 i Am not a “Weber guru”. I have worked pretty ... Oct 7 2018, 07:43 AM
porschetub
i Am not a “Weber guru”. I have worked pretty... Oct 7 2018, 04:16 PM
914Toy Thanks for all the responses. After carefully adju... Oct 7 2018, 04:41 PM
72hardtop
Thanks for all the responses. After carefully adj... Oct 9 2018, 04:22 PM
IronHillRestorations If I resort to reaming jets, I use a Sharpie on th... Oct 7 2018, 04:51 PM
914Toy Thanks Perry. This process is above my paygrade :( Oct 7 2018, 11:04 PM
DaveO90s4 Hi Toy914 and all,
Did you use the Innovate ... Oct 7 2018, 11:51 PM
914Toy
Hi Toy914 and all,
Did you use the Innovate ... Oct 8 2018, 08:25 AM
72hardtop With regards to jetting....
If you're using a... Oct 8 2018, 04:48 AM
gereed75 Hardtop,
that is a very good graph and if you un... Oct 8 2018, 08:20 AM
72hardtop
Hardtop,
that is a very good graph and if you u... Oct 8 2018, 08:47 AM
jfort I have a recently completed 2.7 with DFI, PMOs, JE... Oct 8 2018, 09:32 AM
gereed75 Hmmm. Interesting. Did not think that the Weberâ... Oct 8 2018, 09:54 AM
72hardtop
Hmmm. Interesting. Did not think that the Weber... Oct 8 2018, 10:37 PM
Larmo63 Earlier this year, I had a guy I know tune my Webe... Oct 8 2018, 10:47 PM
72hardtop
Earlier this year, I had a guy I know tune my Web... Oct 8 2018, 10:54 PM
gereed75 Spent some time with the Samba thread - very infor... Oct 9 2018, 09:10 AM
72hardtop
Spent some time with the Samba thread - very info... Oct 9 2018, 11:48 PM
Larmo63 2.4S spec Euro 7R block
36mm heads & manifolds... Oct 9 2018, 02:23 PM
Larmo63 RE: Jetting Webers on 2.7 911 engine. Oct 9 2018, 02:24 PM
gereed75 Larmo,
That is exactly what I am running on may... Oct 9 2018, 06:53 PM
914Toy My engine is running well at all speeds, except fo... Oct 10 2018, 02:03 PM
gereed75 I am not sure where I got these but they graphical... Oct 10 2018, 03:22 PM
72hardtop
My engine is running well at all speeds, except f... Oct 10 2018, 08:17 PM
914Toy
After further research and inspection of the car... Oct 12 2018, 08:49 AM
72hardtop
[quote name='72hardtop' post='2656524' date='Oct ... Oct 12 2018, 10:32 PM
914Toy
[quote name='72hardtop' post='2656524' date='Oct... Oct 13 2018, 08:31 AM
72hardtop
[quote name='72hardtop' post='2656881' date='Oct ... Oct 13 2018, 08:54 AM
914Toy
[quote name='72hardtop' post='2656881' date='Oct... Oct 13 2018, 11:26 AM
914Toy
[quote name='914Toy' post='2656955... Oct 13 2018, 11:31 AM
914Toy Update.
Installing "hatchet" shaped acc... Oct 16 2018, 08:40 AM
72hardtop
Update.
Installing "hatchet" shaped ac... Oct 29 2018, 12:42 AM
larryM y'all may also find this thread relevant
http... Oct 16 2018, 11:15 PM
914Toy Update:
I installed the "hatchet" cams ... Oct 29 2018, 11:18 AM
JmuRiz Good to know, never heard of the hatchet cam, I... Oct 29 2018, 11:41 AM
914Toy Update:
After much reading and testing ideas to di... Nov 7 2018, 01:29 PM
gereed75 Hmmmm....very interesting and extreme diligence on... Nov 7 2018, 05:51 PM
mb911 Interesting.. I actually need a few of those cup w... Nov 8 2018, 05:01 AM
914Toy
Interesting.. I actually need a few of those cup ... Nov 8 2018, 09:54 AM
TravisNeff You can find a lot of the little parts at partskla... Nov 8 2018, 08:55 AM
72hardtop FYI....
There are also 2 types of idle jets used ... Jan 29 2019, 03:06 PM
Mark Henry I'm running same, just a bit bigger main jet o... Jan 29 2019, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 10:31 AM |
