CV Joints, Available again? |
bbrock |
Oct 4 2018, 07:21 AM
I just plugged the OEM CV joint part # into Sunset Porsche's web site and got a hit ($73.64). So these are available again? (IMG:style_emoticons/default/confused24.gif)
https://www.sunsetporscheparts.com/oem-part...int-91433202903 EDIT: Don't Order these! What you get are 25-spline joints which appears to be the part for a 914-6. They won't fit on /4 axles. For more detail, see http://www.914world.com/bbs2/index.php?s=&...t&p=2698908 |
914Sixer |
Oct 14 2018, 11:31 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Originally the early 911 CV's had 6 bolts. Then they changed to 4 and 2 roll pins on the large 108 stub axle. When they switched back to the 100mm axle they went to 6 8mm bolts. After that they went back to the larger 108 again with 6 10mm bolts. My guess is the extra clamping force is need from the 6 bolt application. The VW Thing, 411/412 and VW bus all used 6 bolt 8mm bolts. They all used 100mm CV's with different angles of departure.
For more information go to Blind Chicken Racing CV Joints 101 |
Lo-Fi Version | Time is now: 9th June 2024 - 08:08 AM |
