914bub |
Member ![]() ![]() Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None ![]() |
I collected parts for 3 years for my conversion and finally completed it this week. Now the shifter is super stiff to move anywhere. Here's a little background info:
I installed a side shift transmission and of course converted, shifter, linkage etc. New bushing back at the transmission and a Tangerine bushing at the firewall,(Thanks Chris!) I have only backed it out of the garage, turned it around and backed it back in so I haven't had it on the road to row through the gears. What concerns me is I've had issues before finding gears,(one of the reasons I converted, but not the only one), but now it is very stiff even moving side to side in what is neutral. You know how you can grab your shifter and "wiggle" it side to side without moving it forward or back to select a gear? even moving it there is stiff. It's like something is binding? A little more info. I installed a new complete clutch kit with new flywheel about 1000 miles ago. New clutch cable with the side shift conversion and I also inspected clutch tube in tunnel to be sure it was OK but I know that won't cause shift linkage binding. Pedal assembly is freshly rebuilt as well. I'm just trying to give as much clutch/transmission/shifter info as I can! Any ideas? I've waited four years for first gear and haven't driven the car in 2 years now. While it was down I also installed the stereo, ATS classics with new Michelins, fuel pump conversion and few more things. As you can imagine I'm itchy to try it all out! Any help would be greatly appreciated! |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Did you swap the driver's side warm air guide for the SS version?
Lo-Fi Version | Time is now: 4th July 2025 - 12:51 PM |
