RPMs very slow to drop |
Tdskip |
Oct 16 2018, 03:40 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys-hoping to get some sage advice here on what's going on. I am picking at the 1973 1.7 L D-jet car and when I was test driving her today she did not want to return back to idle.
When you accelerate in first gear up to about 3500 or 4000 RPM and then take your foot off the gas the RPMs stay at the same level or climb slightly and then only slowly drift down. She starts fine and will idle at about 1000 RPM, air bleed screw is close to all the way in. There is an aftermarket return spring on the throttle assembly but appears to have the right amount of tension. I took the air cleaner off and when I manually actually the throttle it appears to settle down faster than when I do it with the gas pedal. The pedal does not appear to be binding on the carpet or interior trim. Any ideas for me? Thanks! |
76-914 |
Oct 18 2018, 01:30 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Then the tube for the throttle cable is severed or loose; split at the end where the cable has worn thru; filthy; or routed incorrectly. (IMG:style_emoticons/default/beerchug.gif)
adolimpio |
Oct 18 2018, 03:37 PM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I had a similar problem recently.
The ends of the wires that make up the cable jacket were very sharp and catching on the cable. I bent the ends of each wire at each end to flare them out a bit and that did the trick - see picture below. (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1539898634.1.jpg) |
worn |
Oct 18 2018, 05:15 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I had a similar problem recently. The ends of the wires that make up the cable jacket were very sharp and catching on the cable. I bent the ends of each wire at each end to flare them out a bit and that did the trick - see picture below. (IMG:http://www.914world.com/bbs2/uploads_offsite/dolimpios.com-11449-1539898634.1.jpg) That is interesting. Harbor Freight sells a cable Oiler that allows you to push oil into this sort of cable. Not sure what people think about that, but I found it helpful. Cable still seems to stick just a wee bit, but for me it is when I try to accelerate. Mine goes back down just fine. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:06 PM |
