123 Ignition Vacuum Adv, Learn me on some vacuum |
nditiz1 |
Jul 11 2018, 06:59 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Ok so I'm currently running the 123ignition dist on my 2056 with dual webers. I read the instructions and don't understand the mapping. I also don't know how it all works together. Can someone educate me on the vacuum adv and what curve would be best? As the rpm's increase it creates more vacuum thus creating more adv, but if I already have a curve setup to go from 12 degrees at idle to 28 degrees at 3000+ will the vacuum adv move the timing even higher once it is hooked up and mapped?
Dave97 |
Oct 29 2018, 08:22 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
Has anyone installed the Bluetooth model? What did you use for both advance curves? Mechanical and vacuum
Lo-Fi Version | Time is now: 9th June 2024 - 03:51 PM |
