> Additional spacer washer on clutch fork pivot ball?, How much to add when have flywheel cut??
jjs3rd914
post Oct 30 2018, 07:11 AM
About to reinstall engine and the original flywheel was
cut 0.025".
The as found spacer washer under the clutch fork pivot ball
is 0.060" thick.
This 0.060" thickness was also found on 2 other 914 transmission we have, so we are assuming this was the standard factory washer thickness used with a new uncut flywheel.
Searching seems to indicate that an additional washer of 0.025" needs to be added to the 0.060" washer under the pivot ball to maintain the geometry.
Can we get confirmation that this is correct. If not then what if anything is to be done to compensate for the flywheel being cut?
Also have others found the original washer was indeed 0.060"
Thanks
jjs3rd914
Lucky9146
post Oct 30 2018, 12:27 PM
I wish I had measured the finished thickness but I got the idea from Forresthaag who said he used and suggested a dime. Had to reduce diameter but that is what I did and it seems to work fine. Hope this helps. Just measured a random dime and it was .046
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg)
- Lo-Fi Version Time is now: 2nd April 2026 - 05:13 PM
