| jjs3rd914 |
Oct 30 2018, 07:11 AM
Member ![]() ![]() Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
About to reinstall engine and the original flywheel was
cut 0.025". The as found spacer washer under the clutch fork pivot ball is 0.060" thick. This 0.060" thickness was also found on 2 other 914 transmission we have, so we are assuming this was the standard factory washer thickness used with a new uncut flywheel. Searching seems to indicate that an additional washer of 0.025" needs to be added to the 0.060" washer under the pivot ball to maintain the geometry. Can we get confirmation that this is correct. If not then what if anything is to be done to compensate for the flywheel being cut? Also have others found the original washer was indeed 0.060" Thanks jjs3rd914 |
| sixnotfour |
Oct 30 2018, 12:37 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
jjs3rd914 Additional spacer washer on clutch fork pivot ball? Oct 30 2018, 07:11 AM
Mark Henry There was no washer originally, you can only add s... Oct 30 2018, 07:21 AM
Dr Evil
About to reinstall engine and the original flywhe... Oct 30 2018, 08:19 AM
JamesM I have never measured, I always just test fit the ... Oct 30 2018, 11:39 AM
Lucky9146 I wish I had measured the finished thickness but I... Oct 30 2018, 12:27 PM
porschetub I found with my clutch adjusted I got gear clash s... Oct 30 2018, 12:38 PM
jjs3rd914 Thanks to all so far.
So I am going to go with wh... Oct 30 2018, 02:20 PM
Dr Evil
So I am going to go with w... Oct 30 2018, 07:56 PM
Lucky9146
So I am going to go with ... Oct 30 2018, 08:12 PM
porschetub
[quote name='Dr Evil' post='2661659' date='Oct 30... Oct 30 2018, 10:54 PM
porschetub Not a lot of thread on there....be careful. Oct 30 2018, 11:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:43 PM |
