| malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,750 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
| Chi-town |
Oct 29 2018, 10:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
There is no "short answer" for this question.
There are some basic references for non forced induction though. WOT = 12.7-13.2 under heavy load Cruise = 13.7-14.7 under light load Idle = Hot-13.0-15.0 / Cold- 11.5-12.5 Now keep in mind all of these are dependent on timing. You need to know where your base timing is set, what your advance curve looks like and your peak advance. This is where those old SUN distributor machines come into play. You need to measure the weights and spring tensions, the diaphragm movement per inch of vacuum in the actuator. Even off the shelf reman distributors often have the wrong curve as they mix and match weights and springs. Now that you've got your distributor curved correctly, timing set, and your wideband O2 installed Now you can tune your carbs or check your F.I. to make sure it's operating correctly. Reading plugs is a good back up to the wideband and will tell you if you're too aggressive or not aggressive enough with timing. Here's some good reading on that: https://honda-tech.com/forums/forced-induct...%2A%2A-3063102/ Remeber always make minor adjustments and don't get crazy aggressive and your engine will last a long time. |
| 72hardtop |
Nov 1 2018, 12:04 AM
Member ![]() ![]() Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
There is no "short answer" for this question. There are some basic references for non forced induction though. WOT = 12.7-13.2 under heavy load Cruise = 13.7-14.7 under light load Idle = Hot-13.0-15.0 / Cold- 11.5-12.5 Now keep in mind all of these are dependent on timing. You need to know where your base timing is set, what your advance curve looks like and your peak advance. This is where those old SUN distributor machines come into play. You need to measure the weights and spring tensions, the diaphragm movement per inch of vacuum in the actuator. Even off the shelf reman distributors often have the wrong curve as they mix and match weights and springs. Now that you've got your distributor curved correctly, timing set, and your wideband O2 installed Now you can tune your carbs or check your F.I. to make sure it's operating correctly. Reading plugs is a good back up to the wideband and will tell you if you're too aggressive or not aggressive enough with timing. Here's some good reading on that: https://honda-tech.com/forums/forced-induct...%2A%2A-3063102/ Remeber always make minor adjustments and don't get crazy aggressive and your engine will last a long time. WOT = 12.7-13.2 under heavy load Cruise = 15.5-17:0 under light load (better MPG's) 14:0 - 15:0 is where the highest EGT's & CHT's will be. Get above that zone when on the progression circuit and below it when on the mains (WOT). Idle isn't where we/one drives so it's out of the pic. Reading plugs takes time. With new plugs you need a couple thousand miles for them to get seasoned. |
malcolm2 Air/Fuel ratio Feb 5 2017, 05:50 PM
jim_hoyland Got this from one of Chris Foley's posts
in A... Feb 5 2017, 06:09 PM
malcolm2 Great. I get to drive to work tomorrow (no rain). ... Feb 5 2017, 06:34 PM
jim_hoyland My experience ( before and after the top end rebui... Feb 5 2017, 07:37 PM
pbanders Agree with the ranges in Jim's posts for varyi... Feb 5 2017, 10:22 PM
ottox914 Getting idle and AFR can be a challenge. As the en... Feb 5 2017, 10:34 PM
plays with cars Peak power is made around 13.5:1, idle is usually ... Feb 6 2017, 12:10 AM
Mark Henry I don't like to see much higher than 13:1 in a... Feb 6 2017, 12:40 AM
Mueller
I don't like to see much higher than 13:1 in ... Feb 10 2017, 03:52 PM
Mark Henry
[quote name='Mark Henry' post='2451811' date='Feb... Feb 10 2017, 06:19 PM
timothy_nd28 :agree: Aircooled engines may need to run slight... Feb 6 2017, 09:41 AM
72hardtop
:agree: Aircooled engines may need to run sligh... Oct 29 2018, 02:29 AM
Keith914 When in doubt, do the spark plug color test. Feb 6 2017, 10:45 AM
Mark Henry
I s... Feb 6 2017, 12:31 PM
porschetub Doing final tune on my Zeniths,dropping idles down... Feb 6 2017, 02:12 PM
Mark Henry
Mark what is the best performing/value AFR kit t... Feb 6 2017, 05:13 PM
porschetub
Mark what is the best performing/value AFR kit ... Feb 6 2017, 07:38 PM
malcolm2 Help me out with WOT. I played with that a little... Feb 6 2017, 03:04 PM
timothy_nd28 I think it would be a cool gauge to have. Would i... Feb 6 2017, 07:05 PM
Mark Henry
I think it would be a cool gauge to have. Would ... Feb 6 2017, 11:06 PM
Porschef It's a great tool to have, especially if you... Feb 7 2017, 05:21 AM
McMark Peak power is made around 13.5:1, ....That's t... Feb 7 2017, 11:31 AM
ConeDodger
Peak power is made around 13.5:1, ....That's ... Feb 7 2017, 11:46 AM
Mark Henry
[quote name='McMark' post='2452311' date='Feb 7 2... Feb 7 2017, 12:05 PM
malcolm2
But on top of the WB meter you should have a head... Feb 7 2017, 02:18 PM
timothy_nd28 350 degrees is not normal, atleast I hope not. Re... Feb 7 2017, 08:47 PM
malcolm2
350 degrees is not normal, atleast I hope not. R... Feb 8 2017, 11:32 AM
malcolm2
350 degrees is not normal, atleast I hope not. R... Feb 8 2017, 12:02 PM
Vacca Rabite
350 degrees is not normal, atleast I hope not. R... Apr 27 2017, 09:13 AM
malcolm2
I'd love to see 350 at 70MPH running up some ... Apr 28 2017, 06:29 AM
ConeDodger The good thing about a CHT gauge is you know your ... Feb 7 2017, 08:51 PM
Mark Henry
The good thing about a CHT gauge is you know your... Feb 8 2017, 07:33 AM
malcolm2
The good thing about a CHT gauge is you know you... Feb 8 2017, 11:37 AM
djway When I set up my L jet that had been horribly mess... Feb 8 2017, 10:11 PM
malcolm2
When I set up my L jet that had been horribly mes... Feb 9 2017, 10:15 AM
djway You are running WAY to rich. At full throttle onl... Feb 9 2017, 08:45 PM
jcd914 If your air flow meter has been mucked with alread... Feb 10 2017, 12:55 AM
falcor75
Stoic for gasoline is 15.8
Ummm, I dont know ... Feb 10 2017, 01:34 AM
djway
Ummm, I dont know... Feb 10 2017, 04:07 AM
Mark Henry If you are running at stoich AFR on an aircooled y... Feb 10 2017, 10:03 AM
malcolm2 On WOT are you documenting at bottom value? I ten... Feb 10 2017, 11:41 AM
malcolm2
On WOT are you documenting at bottom value? I te... Feb 14 2017, 01:30 PM
Porschef Clark, are you referring to the screw on the AFM i... Feb 10 2017, 11:56 AM
malcolm2
Clark, are you referring to the screw on the AFM ... Feb 10 2017, 03:21 PM
Porschef Mark, i get the nickies can deal with a leaner mix... Feb 10 2017, 11:58 AM
Porschef IIRC, I'm at 13.2 or so at cruise. The engine ... Feb 10 2017, 12:06 PM
malcolm2
Of course, there shall be no vacuum leaks...
... Feb 10 2017, 03:26 PM
timothy_nd28 If you have smoke coming out from the dizzy, you w... Feb 10 2017, 04:10 PM
malcolm2
If you have smoke coming out from the dizzy, you ... Feb 10 2017, 04:58 PM
timothy_nd28 AA is now closed, so now your thinking RTV? :D
... Feb 10 2017, 05:23 PM
malcolm2
... Feb 11 2017, 08:37 AM
Mark Henry Just a FYI, PLX has their O2 WB meters on sale ... Feb 10 2017, 06:24 PM
malcolm2
Just a FYI, PLX has their O2 WB meters on sale ... Feb 11 2017, 08:33 AM
Mark Henry
[quote name='Mark Henry' post='2453440' date='Feb... Feb 11 2017, 10:16 AM
timothy_nd28 Those numbers are better than the 18+ numbers you ... Feb 14 2017, 01:47 PM
malcolm2
Those numbers are better than the 18+ numbers you... Feb 14 2017, 02:37 PM
stugray Any leaks coming from the valve cover, dipstick, o... Feb 14 2017, 02:40 PM
timothy_nd28 You tell yourself that while trying to start a Lje... Feb 14 2017, 03:26 PM
pete000 Great read, I am in the exact situation with my 1.... Feb 14 2017, 04:29 PM
malcolm2 No adjustments or significant changes to the readi... Feb 24 2017, 10:14 AM
timothy_nd28 I think your old bent AFM was adjusted abit rich. Feb 24 2017, 10:33 AM
malcolm2
I think your old bent AFM was adjusted abit rich.... Feb 24 2017, 01:01 PM
malcolm2 Mark, I have been studying up on your AFR link fro... Feb 24 2017, 01:04 PM
veekry9 No quick answers,because it's complicated,many... Feb 24 2017, 03:53 PM
pete000 I picked up one of the PLX Blue Tooth AFR systems ... Mar 5 2017, 12:56 AM
Mark Henry Yes 15:1 cruise is too lean for an aircooled 14:1 ... Mar 5 2017, 07:55 AM
72hardtop
Yes 15:1 cruise is too lean for an aircooled 14:1... Apr 24 2017, 05:49 AM
McMark I agree with and support everything Mark Henry has... Mar 5 2017, 09:46 AM
malcolm2 My PLX rig showed up Friday. Looking forward to ge... Mar 5 2017, 08:01 PM
pete000
My PLX rig showed up Friday. Looking forward to g... Mar 6 2017, 11:20 PM
timothy_nd28 Be careful. The air flow meter has a wound up clo... Mar 7 2017, 11:22 AM
malcolm2
Be careful. The air flow meter has a wound up cl... Mar 7 2017, 02:16 PM
pete000 Sounds like these early FI cars are set from the f... Mar 7 2017, 10:59 PM
malcolm2 I do like welding stuff.... but man you can screw ... Mar 10 2017, 02:30 PM
Mark Henry Was your wire feed sticking?
You likely need a new... Mar 10 2017, 03:04 PM
malcolm2
You likely need a ne... Mar 10 2017, 03:10 PM
malcolm2 PLX is now installed. The guage is temp'd in w... Mar 23 2017, 09:55 AM
pete000 I have been playing around a bit with my AFM. I ha... Mar 23 2017, 06:57 PM
malcolm2 My AFM has that jumper. Did not know it was an add... Mar 24 2017, 06:22 AM
malcolm2 5 hours of interstate driving. Several big hills. ... Mar 24 2017, 06:23 AM
Porschef Hey Clark,
PM sent
Joe Mar 24 2017, 07:50 AM
timothy_nd28 Sounds like you are around 26 mpg. I think with t... Mar 24 2017, 10:15 AM
timothy_nd28 I take back what I said. Maybe you are already ge... Mar 24 2017, 10:48 AM
pete000 Tested out my AFM mods and seemed to work well. Wa... Mar 24 2017, 04:49 PM
malcolm2 I made it home.... 800 + mile weekend trip. I don... Mar 27 2017, 03:16 PM
malcolm2 Ok what do you think? Maybe 1000 miles with this ... Mar 27 2017, 04:33 PM
72hardtop
Ok what do you think? Maybe 1000 miles with this... Oct 29 2018, 02:19 AM
timothy_nd28 I got nothing. My work with you is done. Mar 27 2017, 05:10 PM
Mark Henry I'd say that plug is a tad hot, what number is... Mar 27 2017, 05:17 PM
malcolm2
I'd say that plug is a tad hot, what number i... Mar 27 2017, 07:11 PM
Olympic 1.7 Spark plugs are an easy change, you could try NGK ... Mar 28 2017, 07:55 AM
72hardtop This is a great graph for air cooled engines:
htt... Apr 24 2017, 05:38 AM
jpapatrout I just saw an ad for an AFR from Innovate that mon... May 6 2017, 04:24 PM
914Toy
I just saw an ad for an AFR from Innovate that mo... Nov 1 2018, 09:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st October 2026 - 12:39 AM |
