> Crossroads on my 1.8 “refresh”
John90290
post Nov 2 2018, 08:52 AM
I pulled the 1.8 L motor in order to fix all the rust in hell hole which of course gave me the opportunity to fix a few things.
Pulled the heads as the lifter tubes were all leaking oil profusely.
Heads/Valves: Looked to be in good shape with minimal carbon buildup. I was surprised.
Pistons: Look OK I guess... not sure what they’re supposed to look like? They had light carbon buildup on the top of the Pistons but otherwise seems to be OK.
Questions:
Do I buy a new stock pistons and cylinders? if not should I at least change the rings or does it matter?
Can I upgrade to a slightly larger piston without changing the heads and using the original FI?
Should I get one of those modified type 1 oil pumps to replace the oem?
I just want this to be a reliable weekend driver that I can drive through wine country and go coffee and cars.
Valy
post Nov 3 2018, 01:08 PM
When you buy pistons, make sure you get the correct pin height. The 2L has a different measure due to the longer stroke.
There are 94 and 96 pistons for the 1.7/1.8 crank, if that's what you want to do.
Regarding the oil pump, the type 1 has no advantage over the type 4. On the contrary, it's a bit of a headache to get the right one and to make it fit. It also has more places to leak from. The only reason for a type 1 is if your type 4 is bad and can't find a new one (NLA)
- Lo-Fi Version Time is now: 2nd April 2026 - 11:19 AM
