Wires for oil temp sensor into engine bay ?, Green wire with black stripe in harness but not on relay board junctions |
barefoot |
Nov 4 2018, 08:39 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Car is 76 with new late wiring harness. Initial wiring checkout after harness install.
Turn signal on, front & rear run lights flash as intended but signal light on tach just comes on once momentarily. Is this normal, or do I have a wiring issue ?? Well, i tried all 5 of my stash of flasher relays, several showed same symptom of single flash, but 1 worked OK. Now the hi beam indicator bulb works fine but does not show thru to front of Tach, Don't know whats up with this |
Dave_Darling |
Nov 4 2018, 02:08 PM
I remember this being a symptom of a failing flasher relay.
--DD |
Chris914n6 |
Nov 4 2018, 03:18 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:15 AM |
