Wires for oil temp sensor into engine bay ?, Green wire with black stripe in harness but not on relay board junctions |
barefoot |
Nov 4 2018, 08:39 AM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Car is 76 with new late wiring harness. Initial wiring checkout after harness install.
Turn signal on, front & rear run lights flash as intended but signal light on tach just comes on once momentarily. Is this normal, or do I have a wiring issue ?? Well, i tried all 5 of my stash of flasher relays, several showed same symptom of single flash, but 1 worked OK. Now the hi beam indicator bulb works fine but does not show thru to front of Tach, Don't know whats up with this |
tmc914 |
Nov 4 2018, 09:07 AM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
When you use the emergency flashers do the dash indicators flash as expected?
barefoot |
Nov 4 2018, 04:02 PM
When you use the emergency flashers do the dash indicators flash as expected? Well, I swapped in another flasher relay from my stash and the dash indicator flashes OK with the F & R lamps using emergency switch. When i tried the turn signals the indicator lamp started flashing OK, but turned the turn signal lever to the other side and the prior single illumination returned . Trying the emergency flashers again and indicator lamp flashes OK, but both turn signals just flash once. I'll try another of my relays to further research this. Yes, one of my spare relays is working OK. All seemed to work with emergency flasher, but only 1 worked with turn signals. Now my problem is the hi-beam indictor lite bulb is OK if I pull the lamp out of the tach, but it does not show thru to front of tach, what's up with this ?? |
Lo-Fi Version | Time is now: 10th June 2024 - 12:40 AM |
