914GTSTI |
Member ![]() ![]() Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None ![]() |
Keep looking but have not found the answer. This will be using the 4-130 pattern.
So what is the back spacing or off set for the front using a 8x15" wheel .And the rear using a 10" or 12" x 15 " for the rear.( if they will fit) Trying to not use a spacer. Thanks, Randy |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
I have run 15 x 8 front and back with no problems, I used a 13mm 930 spacer on the front.
Currently running 16 X 7 up front with 15mm spacer and 16 x 8 out back no spacers. Plenty of clearance. |
Lo-Fi Version | Time is now: 17th June 2024 - 04:36 AM |
