> Has anyone else experienced trouble, with new windshield trim clips breaking?
ChrisFoley
post Nov 1 2018, 02:10 PM
I am Tangerine Racing
We have to remove a brand new windshield to replace all the New trim clips made by a popular vendor. They're so brittle they all break as soon as you try to install the trim. (IMG:style_emoticons/default/WTF.gif)
More than 3 hours of labor generated by using substandard parts. Seems unfair to charge my customer and I'm not happy about eating that either, except that I'm the one who recommended the vendor. Never again. (IMG:style_emoticons/default/dry.gif)
Buyer beware. I'm going back to Genuine Porsche.
DRPHIL914
post Nov 9 2018, 11:15 AM
Dr. Phil
QUOTE(jsaum @ Nov 8 2018, 11:18 PM) *
QUOTE(Mikey914 @ Nov 4 2018, 06:39 PM) *
We did do our gating differently. And we do a a percentage of recycled material that is used. we can run virgin, and or change to a glass infused delrin. I'm thinking that we will do a preliminary and see when everything falls, possibly utilizing a better material. The feed back we have received on was mostly very good, but even if there is a small problem we will fix it. We also have an idea for a way to check fitment prior to glass being installed that would be handy too.
Plastic molecules align in the direction of flow and are strongest in that direction and weakest in the opposite. If you can tell me the grade I can take a look at the material data sheet. You’ll want a material that has a good flexural modulus. Also look at the elongation at break numbers. I would think an Nylon 66/ ST801 might be a good choice for these parts. Gf delrin might be too brittle. Any GF content isn’t going to allow the part to flex.
QUOTE(Rob-O @ Nov 9 2018, 12:13 AM) *
I don’t think nylon would be a good choice. I’d guess there were initially a PP, with some carbon black added in for color and to help stiffness. The flex mod numbers would be sufficient for this.
I don't know the answer but I am sure you guys will figure this out, it is definitely an issue of being too brittle and not enough flex. there is a good bit of pressure/tension on this part at some locations where the trim is holding onto this, or supposed to. I am sure its a balance of finding enough strength and yet flex with out flexing too much or it wont hold that way either, seems like common sense, but will take some more R& D to figure out where the best balance lies. I would say find some OEM(true Porsche oem not O.E.M.) to test for strength and flex. Like I said, the ones that were in place on my car were original and I ended up pulling or pushing out the pins from the back side to extract the ones that broke and reused those pins to put back in my original clips that we removed when the original glass was pulled and new was installed. Those held just fine on the re-install, but I know I have several clips , the new ones, that snapped off and are not holding the trim at at least 2 locations but once I had the corners in place and held down I was not going to pull it all back up, but I really should. and later on I probably will but installing this trim was such a bit*& I just don't want to try that again for a while and not with out sourcing all new clips and oh the trouble with pulling glass in order to do it - well I did get 2 of the broken clips pulled and new ones installed with glass in place but I don't think I could do that in all locations. I do applaud you for seeing and addressing the issue and making strides to correct it, Thank you. I know you will figure it out!.
ChrisFoley   Has anyone else experienced trouble   Nov 1 2018, 02:10 PM
dr914@autoatlanta.com   the factory trim clips are the only answer, we hav...   Nov 1 2018, 02:20 PM
raynekat   I also have had many trim clips break from a popul...   Nov 1 2018, 03:02 PM
Shadowfax   I broke one when trying to drive it in. Rest seeme...   Nov 1 2018, 03:25 PM
Dave_Darling   If the vendor is one that is responsive to custome...   Nov 1 2018, 05:22 PM
michael7810   I had the same issue but someone told me to test f...   Nov 1 2018, 06:11 PM
mepstein   That sucks. Not a job you want to do 2X.   Nov 1 2018, 06:30 PM
raynekat   That sucks. Not a job you want to do 2X. You c...   Nov 1 2018, 07:54 PM
HansJan   This is concerning. How are the aftermarket parts...   Nov 1 2018, 07:37 PM
raynekat   The clip itself is breaking. And having to shim t...   Nov 1 2018, 07:53 PM
HansJan   @raynekat could this be caused by using the wrong...   Nov 2 2018, 07:49 AM
rhodyguy   While not needing to bash the vendor, it would be ...   Nov 2 2018, 07:54 AM
ChrisFoley   While not needing to bash the vendor, it would be...   Nov 2 2018, 08:08 AM
rhodyguy   It seems anymore OE and OEM can differ. So it...   Nov 2 2018, 08:15 AM
Shadowfax   It seems anymore OE and OEM can differ. So it...   Nov 2 2018, 08:26 AM
mepstein   It seems anymore OE and OEM can differ. So it...   Nov 3 2018, 05:51 AM
dr914@autoatlanta.com   The factory clips are a bit flexible to allow for ...   Nov 2 2018, 08:19 AM
rhodyguy   Here's an example. Pelican. The less expensive...   Nov 2 2018, 09:17 AM
bbrock   Here's an example. Pelican. The less expensiv...   Nov 2 2018, 09:22 AM
rhodyguy   O.E.M. vs OEM. The portion that presses in is off ...   Nov 2 2018, 10:13 AM
Chi-town   Odd question but what temp is it there when these ...   Nov 2 2018, 11:05 AM
raynekat   Odd question but what temp is it there when these...   Nov 2 2018, 02:22 PM
Mikey914   Lets look at the failure mode on the clips. Is it ...   Nov 2 2018, 10:45 PM
raynekat   I can't speak for others, but this is where mi...   Nov 3 2018, 12:40 AM
michael7810   I can't speak for others, but this is where m...   Nov 4 2018, 06:09 AM
jmitro   thanks for posting this concern; I just installed ...   Nov 3 2018, 05:37 AM
Bartlett 914   Maybe something changed along the way. I have had ...   Nov 3 2018, 08:08 AM
76-914   :popcorn:   Nov 3 2018, 08:21 AM
Mikey914   The factory ones to break over time. Many of us ha...   Nov 3 2018, 12:18 PM
buck toenges   I have used Mark's clips and broke a bunch whi...   Nov 4 2018, 11:35 AM
Mikey914   That's why I'm asking. Please do post up p...   Nov 4 2018, 12:17 PM
jsaum   I’ve been in the plastic injection molding indus...   Nov 4 2018, 05:28 PM
davep   Some of things I would look at is the same materi...   Nov 8 2018, 09:05 PM
DRPHIL914   you can check my build thread I brought this up ba...   Nov 4 2018, 05:58 PM
Mikey914   We did do our gating differently. And we do a a pe...   Nov 4 2018, 08:39 PM
jsaum   We did do our gating differently. And we do a a p...   Nov 8 2018, 10:18 PM
jacksun   HI, Would it be possible to change the geometry of...   Nov 5 2018, 04:23 AM
HansJan   HI, Would it be possible to change the geometry o...   Nov 7 2018, 09:46 AM
ChrisFoley   Original ones are still available at Porsche? ...   Nov 7 2018, 10:15 AM
ChrisFoley   Here are two pics of failed parts, typical of what...   Nov 5 2018, 10:20 AM
raynekat   Similar to the failures on mine.... Here are two...   Nov 5 2018, 10:43 AM
rhodyguy   hard to imagine why the failure occurs in that spe...   Nov 5 2018, 10:56 AM
Mikey914   It appears to be a materials issue. It did shear. ...   Nov 5 2018, 11:40 PM
jsaum   It appears to be a materials issue. It did shear....   Nov 8 2018, 10:05 PM
SteveL   I haven't bought or used any of these windshie...   Nov 6 2018, 07:23 AM
Rob-O   I don’t think nylon would be a good choice. Iâ€...   Nov 8 2018, 11:13 PM
jfort   I posted about this issue earlier with regard to s...   Nov 9 2018, 10:22 AM
rhodyguy   The OEM/O.E.M. thing is weird. The clip listing at...   Nov 9 2018, 10:54 AM
DRPHIL914   [quote name='Mikey914' post='2663179' date='Nov 4...   Nov 9 2018, 11:15 AM
Mikey914   We've done some research on these over the las...   Nov 10 2018, 12:36 PM
raynekat   Yes, it makes sense to offer more than the 19 clip...   Nov 10 2018, 02:04 PM
raynekat   OK....round 3 for the windshield install. This ti...   Nov 13 2018, 11:01 AM
mepstein   OK....round 3 for the windshield install. This t...   Nov 13 2018, 11:10 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:48 PM
