Venting of the fuel tank charcoal filter with carbs - Where, Weber conversion |
jjs3rd914 |
Nov 9 2018, 04:47 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Just finishing a 2056 build with weber 40's.
With the D-jet FI system on our 1972 there is a hose that came from an output nipple on the passenger side of the fan housing to input of the charcoal canister in the front trunk. The output return line from the canister plugged into the air cleaner. This system blew air from the fan housing thru the canister and I believe sucked the vapor out of the tank routing it back to the air cleaner. So with the carb conversion I would still like to vent the fuel tank vapors but where would be the place to do it? We could modify one of the new air cleaners and place the return line there, or maybe put a vent in each air cleaner and vent into both with a tee. Or just it safely somewhere to atmosphere. O I suppose eliminate the charcoal canister altogether, but then how does the fuel tank get vented? What have all of you done with this with the carb conversion. Thanks jjs3rd914 |
bbrock |
Nov 9 2018, 05:58 PM
We could modify one of the new air cleaners and place the return line there, or maybe put a vent in each air cleaner and vent into both with a tee. Either of these. The idea is to burn the vapor to reduce pollution. Removing the canister creates a lot of stinky gas fumes for you to breath. Just route the hose that went to the air box to one or both filters on the carbs. (IMG:style_emoticons/default/beerchug.gif) |
SirAndy |
Nov 9 2018, 06:12 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
We could modify one of the new air cleaners and place the return line there, or maybe put a vent in each air cleaner and vent into both with a tee. Either of these. The idea is to burn the vapor to reduce pollution. Removing the canister creates a lot of stinky gas fumes for you to breath. Just route the hose that went to the air box to one or both filters on the carbs. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) I removed my charcoal canister many, many moons ago and that is one of the few things i regret every time i go on a twisty drive. (IMG:style_emoticons/default/icon8.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 01:26 AM |
