Venting of the fuel tank charcoal filter with carbs - Where, Weber conversion |
jjs3rd914 |
Nov 9 2018, 04:47 PM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Just finishing a 2056 build with weber 40's.
With the D-jet FI system on our 1972 there is a hose that came from an output nipple on the passenger side of the fan housing to input of the charcoal canister in the front trunk. The output return line from the canister plugged into the air cleaner. This system blew air from the fan housing thru the canister and I believe sucked the vapor out of the tank routing it back to the air cleaner. So with the carb conversion I would still like to vent the fuel tank vapors but where would be the place to do it? We could modify one of the new air cleaners and place the return line there, or maybe put a vent in each air cleaner and vent into both with a tee. Or just it safely somewhere to atmosphere. O I suppose eliminate the charcoal canister altogether, but then how does the fuel tank get vented? What have all of you done with this with the carb conversion. Thanks jjs3rd914 |
jjs3rd914 |
Nov 10 2018, 10:36 AM
Done deal,
We will vent the fuel vapors into the carb air cleaners. So as to not favor one carb over the other we will use a tee and vent to both.. So this adds another question. Does the fuel vapor actually affect the air fuel mixture. In order words do the carbs now have to be re-adjusted to compensate for air that already has some fuel vapor in it. The car seems to run terrific during initial test runs. So we will check after the mod and adjust accordingly Thanks for all the advise. jjs3rd914 |
Lo-Fi Version | Time is now: 23rd May 2024 - 01:49 AM |
