OT Do we have any factory Mercedes Technicians here, GLK Blower Motor/Resistor Issue |
seanery |
Nov 13 2018, 12:41 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Hi guys, I have a 2012 GLK with 36,000 miles on it. The car is in great shape. Recently, I've had issues with the AC/Heat blower motor. It started to work intermittently, then stopped altogether. I read a bit online and see that is a common problem with Mercedes. The issue coming down to blower motor failure or resistor failure.
I bought a new blower motor, but before I installed it, I plugged it into the resistor in the car and it was a no go. So I ordered a resistor and had it overnighted. It showed up this morning, I tested it with the old fan, plugged both in, turned the car on and the fan worked. I packed it all up, put the bits back together and turned the car on, and no go. Right back to where I was before. I tested the voltage coming TO the resistor and get 14.7-14.9V. I test both units outputs and get .7V. Obviously not enough to drive a van. The thing that gets me is that it did work for my 30 second test. As for wires that go to Resistor: 1. Power 2. Common 3. Yellow wire? Sensor? I'm not sure what this does Wires from the Resistor: 1. Power to fan connector 2. Common to fan connector The fan control powers up, and I can hear things change when I change modes, etc...The car makes AC and heat, just doesn't blow it. I'm in a huge timecrunch and this is baffling me! And BEHR is such a big, machine that getting a hold of someone there has proven fruitless. Any help? Ideas? TIA! |
seanery |
Nov 13 2018, 05:14 PM
Luckily for me, they are relatively easy to get to. I wish my problem were as solveable as yours proved to be. I had to slide small paperclips into the factory harness to get my meter reading on them - my meter's probes were too large. Even the tiny paperclips made a good connection, and I'd be terribly surprised if both resistors and both fans had the same problem. If I put voltage to the fans, they bot spin.
Lo-Fi Version | Time is now: 3rd June 2024 - 02:39 AM |
