Alternator light question, concerned about a voltage drop an alternator light starting to come on |
DRPHIL914 |
Nov 16 2018, 05:25 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I am about three hours into a 5 Hour Dr. on my way to Atlanta I just noticed a little while ago maybe 10 minutes ago a slight dim Flickr or glow from my alternator light also then looking at my voltage gauge which with my lights on normal he reads 11.5 V but it now reads 10.5 phones. Also at one point I hit a bump and the light disappeared in the voltage went back up to 11.5 but then after a few minutes the voltage drop again and the light is now on very faintly but it is so here’s my question what is the most likely cause is it a loose wire somewhere is it a loose belt those are the two most likely scenarios to me but if it’s a wire what should I look for I know I’m going to have to stop to look and right now I hit a bump** edited** as I’m driving right now and the light went out . So what light is most likely loose and causing this issue I’m going to have to stop and figure it out I guess thank you for the SAP help and responses in advance, Dr. Phil
I think you can see from this picture the light is on when I turn the other lights off you can see the faint glow of the alternator light and maybe even a little bit and the other picture with the lights on Attached thumbnail(s) |
DRPHIL914 |
Nov 16 2018, 09:12 PM
i might swap that out tomorrow, i got here fine, 6.5 hour drive due to traffic and detours
so on. but it also would come and go, sometimes not related to any bump or jolt- maybe a loose wire or bulb? seems tight at coil. i forgot my voltage tester, i do have my timing light in the bag. just need to get to Shades tomorrow, its only 12 miles! will post pictures ! |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:47 AM |
