Alternator light question, concerned about a voltage drop an alternator light starting to come on |
DRPHIL914 |
Nov 16 2018, 05:25 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I am about three hours into a 5 Hour Dr. on my way to Atlanta I just noticed a little while ago maybe 10 minutes ago a slight dim Flickr or glow from my alternator light also then looking at my voltage gauge which with my lights on normal he reads 11.5 V but it now reads 10.5 phones. Also at one point I hit a bump and the light disappeared in the voltage went back up to 11.5 but then after a few minutes the voltage drop again and the light is now on very faintly but it is so here’s my question what is the most likely cause is it a loose wire somewhere is it a loose belt those are the two most likely scenarios to me but if it’s a wire what should I look for I know I’m going to have to stop to look and right now I hit a bump** edited** as I’m driving right now and the light went out . So what light is most likely loose and causing this issue I’m going to have to stop and figure it out I guess thank you for the SAP help and responses in advance, Dr. Phil
I think you can see from this picture the light is on when I turn the other lights off you can see the faint glow of the alternator light and maybe even a little bit and the other picture with the lights on Attached thumbnail(s) |
VaccaRabite |
Nov 19 2018, 09:02 AM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I chased this for weeks over the summer. You have a grounding issue. Search my thread and you can read all the stuff that went into fiding the issue, and all the fantastic troubleshooting advice I got from Spoke and Clay and others.
I fixed it by running a heavy gauge wire from the alternator case to the chassis ground point behind the relay board. It does NOT take much resistance in ground to cause an issue, and the loss of a volt or two is huge. Zach I would also feel around the bottom of the VR plug on the relay board to make sure you have not pushed a connector through the tar. I did that too. |
DRPHIL914 |
Nov 19 2018, 12:07 PM
I chased this for weeks over the summer. You have a grounding issue. Search my thread and you can read all the stuff that went into fiding the issue, and all the fantastic troubleshooting advice I got from Spoke and Clay and others. I fixed it by running a heavy gauge wire from the alternator case to the chassis ground point behind the relay board. It does NOT take much resistance in ground to cause an issue, and the loss of a volt or two is huge. Zach I would also feel around the bottom of the VR plug on the relay board to make sure you have not pushed a connector through the tar. I did that too. I remember seeing your thread. I did check the relay board and this was all rechecked and tested when I was having grounding issue with my fuel pump. Bottom of board is in perfect condition. But I will check ground and voltage as suggested above in the other post, it could be the fan housing is not making a good ground due to the powder coating? I can easily run a ground wire from the alternator case to the chassis and see if that helps. So either the alternator is dying or its not grounding so it cant properly do so. I hope its that simple. you would think a brand new Bosch alternator would not be the cause of this, and that is certainly easier than having to pull the whole alternator out! I have a new alternator harness in there so I would not suspect this unless a contact or ground is loose. |
Lo-Fi Version | Time is now: 23rd May 2024 - 01:41 PM |
