Early worm drive window regulator source, Outer guide cracked |
phillstek |
Nov 21 2018, 02:16 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Does anyone here know where I can get a left side new/reco window drive?
There's a supplier here that has them for early bay window kombis that are the same mechanism but with a different radius that I may be able to adapt. Thanks |
phillstek |
Nov 21 2018, 01:02 PM
Thanks for the reply.
It appears to be always the left one that fails as it's the one that is the most heavily used. Having converted my car to right hand drive this isn't such a big deal for me but I'd like to repair it all the same. It's the outer metal guide tube that's sheared in half right where the pinion drive is attached so any attempt to raise the window forces the inner rack out of the tube. Maybe it can be welded? Thanks again. |
dr914@autoatlanta.com |
Nov 21 2018, 01:38 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
one of our mechanics has fixed a few of them, so I am sure that you can probably fix yours. We have plenty of good right ones if you want to get one to repair yours, 25 bucks!!!
Thanks for the reply. It appears to be always the left one that fails as it's the one that is the most heavily used. Having converted my car to right hand drive this isn't such a big deal for me but I'd like to repair it all the same. It's the outer metal guide tube that's sheared in half right where the pinion drive is attached so any attempt to raise the window forces the inner rack out of the tube. Maybe it can be welded? Thanks again. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:10 PM |
