Type 4 rebuild questions |
mepstein |
Nov 19 2018, 08:14 PM
914-6 GT in waiting Group: Members Posts: 19,310 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What can I do to rebuild my 1.7 for more HP and torque but keep the original d-jet.
piston and cylinders crank camshaft heads ? I know I can't change the cam too much but is there one that will do better and still work with d-jet. I know there is modern FI but I'm not interested. No carbs. I'm not looking for all out HP or dropping 10K on an engine kit. I just want a nice bump in power, if possible, while keeping a stock looking engine. |
mepstein |
Nov 20 2018, 02:50 PM
I already have 94mm Mahle P&C's, 2.0 crank and a FI cam kit. I'm wondering if any of those things will make a difference if I rebuild the engine. If it's little to none, or not a combo that will work, I won't bother. If I could get another 15hp, well that's a 20% increase on that engine so It would be worth it to me.
I have a 250lb weight reduction planned (on paper) so a little boost with a much lighter car would make it fun. |
rgalla9146 |
Nov 21 2018, 04:58 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I already have 94mm Mahle P&C's, 2.0 crank and a FI cam kit. I'm wondering if any of those things will make a difference if I rebuild the engine. If it's little to none, or not a combo that will work, I won't bother. If I could get another 15hp, well that's a 20% increase on that engine so It would be worth it to me. I have a 250lb weight reduction planned (on paper) so a little boost with a much lighter car would make it fun. What year chassis are you using ? Where will the -250 lb come from ? (IMG:style_emoticons/default/idea.gif) |
mepstein |
Nov 21 2018, 05:15 PM
I already have 94mm Mahle P&C's, 2.0 crank and a FI cam kit. I'm wondering if any of those things will make a difference if I rebuild the engine. If it's little to none, or not a combo that will work, I won't bother. If I could get another 15hp, well that's a 20% increase on that engine so It would be worth it to me. I have a 250lb weight reduction planned (on paper) so a little boost with a much lighter car would make it fun. What year chassis are you using ? Where will the -250 lb come from ? (IMG:style_emoticons/default/idea.gif) A ‘71 Here are some of the things I came up with to remove 250-300 lbs. not all of the items are practical, reasonable or cost effective but it was just spitballing while waiting on a flight home. A 300lb / 15% weight reduction would make a pretty good difference in acceleration, braking and handling without changing the brakes, engine or suspension. 10 - Firewall pad 10 - floor tar 60 - lids 10 - engine lid 5 - rockers 20 - glass bumpers 20 - targa top 5 - carpet 15 - exhaust 10 - Backpad 20 - air control 5 - door hardware 185 10 - Seat sliders 5 - interior padding 20 - headlights 10 - steel crossbar 10 - Heat flappers & lever 30 - battery and 5 - battery tray 265 20- Headers 310 Additional items- Pedal board Targa latches Vent window & trim Shortened sub dash Sun visors Glove box & ashtray Trunk locks F & R Glove box lock Windshield wipers Windshield washer Trunk heat shield ? Brake caliper shields Radio & speakers Engine lid latch & cable Front trunk latch & cable Front carpet board Spare tire Center tunnel covers Shift knob Antenna |
worn |
Nov 21 2018, 06:14 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I already have 94mm Mahle P&C's, 2.0 crank and a FI cam kit. I'm wondering if any of those things will make a difference if I rebuild the engine. If it's little to none, or not a combo that will work, I won't bother. If I could get another 15hp, well that's a 20% increase on that engine so It would be worth it to me. I have a 250lb weight reduction planned (on paper) so a little boost with a much lighter car would make it fun. What year chassis are you using ? Where will the -250 lb come from ? (IMG:style_emoticons/default/idea.gif) A ‘71 Here are some of the things I came up with to remove 250-300 lbs. not all of the items are practical, reasonable or cost effective but it was just spitballing while waiting on a flight home. A 300lb / 15% weight reduction would make a pretty good difference in acceleration, braking and handling without changing the brakes, engine or suspension. 10 - Firewall pad 10 - floor tar 60 - lids 10 - engine lid 5 - rockers 20 - glass bumpers 20 - targa top 5 - carpet 15 - exhaust 10 - Backpad 20 - air control 5 - door hardware 185 10 - Seat sliders 5 - interior padding 20 - headlights 10 - steel crossbar 10 - Heat flappers & lever 30 - battery and 5 - battery tray 265 20- Headers 310 Additional items- Pedal board Targa latches Vent window & trim Shortened sub dash Sun visors Glove box & ashtray Trunk locks F & R Glove box lock Windshield wipers Windshield washer Trunk heat shield ? Brake caliper shields Radio & speakers Engine lid latch & cable Front trunk latch & cable Front carpet board Spare tire Center tunnel covers Shift knob Antenna Funny. I made a couple of pedal boards out of alu honeycomb. No one was interested. But they weigh like a feather. A cheap router bit and the honeycomb. |
Lo-Fi Version | Time is now: 5th June 2024 - 04:28 AM |
