> revisiting After side shift tranny rebuild - still shift into 1st issues, About 50% goes shift right in, 50% no can do
jjs3rd914
post Nov 20 2018, 12:23 PM
Side shift tranny rebuilt
All gears shift beautiful but 1st, linkage adjusted properly, bushings all new
No issues with clutch tube in tunnel
New PP, TO bearing, 6 spring clutch disk
Stock flywheel cut .025" and TO bearing fork pivot ball washer added by .025" to the stock .060"
All motor mounts good
Clutch adjusted properly
Used very good 1st reverse slider
Used almost new 2nd-5th dog teeth with appropriate brake bands etc.
Used NEW synchro ring
About half the time it goes right into 1st very smoothly. No grinding, no issues with reverse, linkage feels great. Other times will not budge into 1st gear. By going into 3rd gear first then trying seems to work most of the time as workaround.
SO after reading numerous threads we have concluded that could the issue be
1. Are new synchros much stiffer than used one. SO DO THEY NEED TO BE WORN IN?
Could that be part of the problem and could problem diminish with use?
2. And Using a 2-5 dog tooth gear and brake bands also be part of the problem?
I do have original 1st gear brake band and am willing to buy the correct 1st gear dog gear.
Also I have many good usable "worn in" synchro rings to use instead of the new one.
So if problem does not go away, could I be faced to replace the above to get it right?
I have no issue doing so. Just want it right.
So anyone else faced with simliar issue and how did you solve it. Some Prior threads seem to point into maybe not using a new synchro and not using the 2-5 dog gear.
Thanks
jjs3rd914
jjs3rd914
post Nov 21 2018, 02:59 PM
Thanks all,
Yes all bushing are lubricated. Everything done by the book on the rebuild. I'm using Kendall NS-MP 80w-90, which I use in our 74 911 as well.
I've read that Swepco will find a leak very easily--True??
Anyhow. My best luck is going into 3rd then1st, seems to work better than going into 2nd. It also seems to help by going into first directly when just coming to a stop as others have pointed out. That works great at a stop sign, but at an long red light - nah do not want to leave clutch in while waiting.
So we'll give it some time to break in and report back.
But it seems to me there must be a solution without going exotic like cable shifters etc.
I can tell you. I bought a new 914 in 1972 (yes we are that old and only paid around $4300) and that was of course a tail shifter. I do not remember having this type of issue we are having now with a side shift! Of course that was xxx years ago so memory might be a little foggy.
Thanks
jjs3rd914
dr914@autoatlanta.com
post Nov 21 2018, 03:04 PM
Swepco is super slick and good for the syncros and making the car easier to shift. A lot of the racers use it
QUOTE(jjs3rd914 @ Nov 21 2018, 01:59 PM) *
Thanks all,
Thanks
jjs3rd914
jjs3rd914
post Nov 22 2018, 07:37 AM
I think it is Red Line fluid that tends to finds leaks more than others. I do not mean to reference Swepco or Red Line in a negative way. If my problem persists, I will give it Swepco a try.
Thanks
jjs3rd914
QUOTE(dr914@autoatlanta.com @ Nov 21 2018, 01:04 PM) *
Thanks all,
Thanks
jjs3rd914
- Lo-Fi Version Time is now: 2nd April 2026 - 10:32 AM
