| tornik550 |
Nov 24 2018, 02:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently purchased a PMO carb setup for my /6. My car has never used a fuel return hose since I purchased it many years ago. Do I really need to use the fuel return? My car is just for street driving. I am not really even sure what the fuel return is used for. I am trying to avoid using it because the fuel return lines in the tunnel have been removed by the previous owner and I really don’t want to install new ones.
| SirAndy |
Nov 24 2018, 02:46 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am not really even sure what the fuel return is used for. The fuel return keeps the fuel circulating through the system, thus preventing it from getting too hot (or even boiling) while sitting in the float bowls. (IMG:style_emoticons/default/shades.gif) |
tornik550 Fuel return with carbs- needed? Nov 24 2018, 02:17 PM
914Toy
I recently purchased a PMO carb setup for my /6. ... Nov 24 2018, 02:30 PM
Retroracer I run a similar setup to 914Toy. /6 engine running... Nov 24 2018, 03:20 PM
sithot You can dead-head with a pump making correct press... Nov 24 2018, 03:47 PM
mb911 I am using the PMO return regulator for my test st... Nov 24 2018, 04:35 PM
Mark Henry Needed? No
Better set up? Yes. Nov 24 2018, 04:59 PM
914Toy
Needed? No
Better set up? Yes.
Aaaaah!, mo... Nov 24 2018, 05:47 PM
Mark Henry
Needed? No
Better set up? Yes.
Aaaaah!, m... Nov 25 2018, 09:43 AM
Retroracer :agree:
- Tony Nov 24 2018, 05:04 PM
brant I agree fully that a return system would the corre... Nov 25 2018, 10:21 AM
bbrock I'm not seeing how there are more parts to fai... Nov 25 2018, 10:36 AM
porschetub A constant running low pressure pump would benefit... Nov 25 2018, 02:30 PM
Chi-town A dead head regulator is hard on high pressure pum... Nov 25 2018, 05:05 PM
sithot
A dead head regulator is hard on high pressure pu... Nov 26 2018, 09:41 AM
VaccaRabite When my car had carbs I never bothered with a retu... Nov 27 2018, 08:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:34 PM |
