| tornik550 |
Nov 24 2018, 02:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently purchased a PMO carb setup for my /6. My car has never used a fuel return hose since I purchased it many years ago. Do I really need to use the fuel return? My car is just for street driving. I am not really even sure what the fuel return is used for. I am trying to avoid using it because the fuel return lines in the tunnel have been removed by the previous owner and I really don’t want to install new ones.
| Mark Henry |
Nov 24 2018, 04:59 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Needed? No
Better set up? Yes. |
| 914Toy |
Nov 24 2018, 05:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
| Mark Henry |
Nov 25 2018, 09:43 AM
How's that? Were every stock FI 914s going up in flames? Almost every big HP set-ups uses a return. Deadheading is now mostly something done only on low HP engines. |
tornik550 Fuel return with carbs- needed? Nov 24 2018, 02:17 PM
914Toy
I recently purchased a PMO carb setup for my /6. ... Nov 24 2018, 02:30 PM
SirAndy I am not really even sure what the fuel return is... Nov 24 2018, 02:46 PM
Retroracer I run a similar setup to 914Toy. /6 engine running... Nov 24 2018, 03:20 PM
sithot You can dead-head with a pump making correct press... Nov 24 2018, 03:47 PM
mb911 I am using the PMO return regulator for my test st... Nov 24 2018, 04:35 PM
Retroracer :agree:
- Tony Nov 24 2018, 05:04 PM
brant I agree fully that a return system would the corre... Nov 25 2018, 10:21 AM
bbrock I'm not seeing how there are more parts to fai... Nov 25 2018, 10:36 AM
porschetub A constant running low pressure pump would benefit... Nov 25 2018, 02:30 PM
Chi-town A dead head regulator is hard on high pressure pum... Nov 25 2018, 05:05 PM
sithot
A dead head regulator is hard on high pressure pu... Nov 26 2018, 09:41 AM
VaccaRabite When my car had carbs I never bothered with a retu... Nov 27 2018, 08:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:56 AM |
