> Wont start, struggling
ericoneal
post Nov 26 2018, 07:56 AM
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing.
Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not.
Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before...
Anything else to try would be helpful. THanks
dr914@autoatlanta.com
post Nov 26 2018, 09:19 AM
check the dwell angle and make sure it is good at 50. Also check the leads to the coil, green and black with purple on the 1 or negative side, and black on the positive or 15 side. After that check the fuel pump to make sure that it is delivering fuel by removing a the hose where it comes up into the engine bay and putting it into a bottle and turn the key on to start the pump running. It should deliver a steady stream.
You can also statically set the timing to get it close to where it should be by putting the car on number one top dead center on a compression stroke and the zero mark on the fan. Then put a test light on the negative side of the coil and move both ways a bit to where the light turns and then just turns off. When it just turns off that should be timing on zero degrees, good enough to start the engine. Beyond that you could have a carb problem where maybe after sitting the floats are sticking
QUOTE(ericoneal @ Nov 26 2018, 06:56 AM) *
ericoneal
post Nov 26 2018, 10:29 AM
Pretty sure the coil is wired correctly, I took pictures before I unhooked it, odd that the tach is no longer working though..
Fuel pump is running and fuel is squirting into carbs, will check to be sure its steady tonight. Also checked to be sure rotor was pointing are plug 1 when at TDC on fan. Test light is good idea, will check that as well.
Will Google sticky floats.
Thanks
QUOTE(dr914@autoatlanta.com @ Nov 26 2018, 10:19 AM) *
ericoneal   Wont start   Nov 26 2018, 07:56 AM
dr914@autoatlanta.com   check the dwell angle and make sure it is good at ...   Nov 26 2018, 09:19 AM
ericoneal   Pretty sure the coil is wired correctly, I took pi...   Nov 26 2018, 10:29 AM
Mblizzard   Because the Tach draws its signal from the coil, I...   Nov 26 2018, 12:08 PM
Tdskip   If you didn't move the distributor when the en...   Nov 26 2018, 12:16 PM
IronHillRestorations   Spark, air, fuel, compression. It's one of th...   Nov 26 2018, 01:52 PM
ericoneal   Still no luck, here is what I did: 1. I checked ...   Nov 26 2018, 08:11 PM
Tdskip   That sounds like a P-51 Merlin warming up. Seems ...   Nov 26 2018, 10:09 PM
second wind   I lost three months of run time with my car due to...   Nov 26 2018, 11:13 PM
Mblizzard   I have o say its fuel as well. Do the standard sp...   Nov 27 2018, 08:03 AM
ericoneal   I sprayed fluid in the carbs and it fires up easie...   Nov 27 2018, 08:36 AM
mobymutt   I sprayed fluid in the carbs and it fires up easi...   Nov 27 2018, 09:16 AM
rhodyguy   Is it possible to maintain 2.7-3k rpm with a stead...   Nov 27 2018, 08:52 AM
IronHillRestorations   How long did it sit? My guess is the fuel that wa...   Nov 27 2018, 09:50 AM
ericoneal   Sent the video to a local guy here who is very goo...   Nov 27 2018, 11:54 AM
Mblizzard   Sent the video to a local guy here who is very go...   Nov 27 2018, 12:19 PM
ericoneal   Its a single hexbar between the two. Pretty sure ...   Nov 27 2018, 12:20 PM
Tdskip   You should be able to disconnect the bar and set e...   Nov 27 2018, 12:26 PM
Mblizzard   You should be able to disconnect the bar and set ...   Nov 27 2018, 12:31 PM
TheCabinetmaker   Sounds like the engine is fighting itself to run f...   Nov 28 2018, 11:55 AM
Triaddave   It may sound stupid but maybe a kinked fuel line o...   Nov 28 2018, 12:12 PM
marksteinhilber   You have unsteady firing from a number of cylinder...   Nov 28 2018, 02:09 PM
ericoneal   I will double check the spark tonight by pulling t...   Nov 28 2018, 03:35 PM
cgnj   I will double check the spark tonight by pulling ...   Nov 29 2018, 05:05 AM
sdoolin   Watched the video also. I think you have a linkage...   Nov 29 2018, 07:33 AM
ericoneal   Thats why this website is great. PMed received, w...   Nov 29 2018, 11:30 AM
Mblizzard   Thats why this website is great. PMed received, ...   Nov 29 2018, 12:10 PM
Tdskip   Making progress....please keep us posted and someo...   Nov 29 2018, 01:50 PM
ericoneal   I got it covered.. Making progress....please kee...   Nov 29 2018, 03:35 PM
cgnj   post a pic of your carbs and linkage as they are c...   Nov 30 2018, 05:18 AM
ericoneal   sdoolin rolled over this afternoon in his great lo...   Nov 30 2018, 09:26 PM
wndsrfr   sdoolin rolled over this afternoon in his great l...   Dec 1 2018, 07:21 AM
sdoolin   As Eric said, not a fuel issue. We removed and cle...   Dec 1 2018, 09:02 AM
Tdskip   Well - look at it this way, the carb work sounds l...   Dec 1 2018, 09:54 AM
cgnj   basics 101 At this point, I would jack it jp put ...   Dec 1 2018, 11:23 AM
injunmort   do you have access to a timing light? how are you ...   Dec 1 2018, 01:29 PM
ericoneal   do you have access to a timing light? how are you...   Dec 1 2018, 01:34 PM
injunmort   yes, there is more to it than that. are you runnin...   Dec 6 2018, 09:27 AM
ericoneal   Thanks, I'm familar with timing the engine onc...   Dec 6 2018, 09:48 AM
injunmort   you must make sure points are opening when you set...   Dec 6 2018, 12:50 PM
rhodyguy   Try turning the idle up using ONE idle speed adjus...   Dec 6 2018, 01:25 PM
mobymutt   Are you sure the firing order is correct? My car i...   Dec 6 2018, 01:59 PM
wndsrfr   Are you sure the firing order is correct? My car ...   Dec 6 2018, 04:59 PM
Rand   I haven't read the whole thread. But you know ...   Dec 6 2018, 05:11 PM
Spoke   In the video, your first key turn resulted in the ...   Dec 7 2018, 06:48 PM
Tdskip   In the video, your first key turn resulted in the...   Dec 7 2018, 08:39 PM
second wind   For $50 I would buy a new coil to totally eli...   Dec 7 2018, 07:20 PM
Rand   Coils have a VERY low failure rate. Test first.   Dec 7 2018, 08:35 PM
ericoneal   I got the new starter on today, so at least I am b...   Dec 7 2018, 09:15 PM
Tdskip   0.016", same as any other 914 or Type IV moto...   Dec 8 2018, 01:56 AM
mobymutt   Maybe post some pictures of the wires, distributer...   Dec 8 2018, 01:57 PM
ericoneal   Tested the coil and am getting a strong white spar...   Dec 9 2018, 10:36 AM
cgnj   Tested the coil and am getting a strong white spa...   Dec 9 2018, 11:30 AM
Spoke   The item on the side of the distributor is the vac...   Dec 9 2018, 10:48 AM
ericoneal   Tried that too. At this point just going through ...   Dec 9 2018, 11:08 AM
Spoke   Tried that too. OK, so you sprayed starting flu...   Dec 9 2018, 11:46 AM
cuddy_k   I’m thinking fuel as well. Could be that the pum...   Dec 9 2018, 11:14 AM
ericoneal   After spraying, it takes a few times, then starts ...   Dec 9 2018, 11:50 AM
Spoke   After spraying, it takes a few times, then starts...   Dec 9 2018, 12:32 PM
euro911   Have you checked the fuel pressure at the carb...   Dec 9 2018, 02:49 PM
injunmort   you have still not timed it. yes the distributor a...   Dec 9 2018, 02:54 PM
tom.esh   How old is the gas in the tank? Could it just be b...   Dec 9 2018, 03:03 PM
Tdskip   Bump for an update and any help needed to get you ...   Dec 11 2018, 08:21 AM
ericoneal   I'm starting to think its a fuel pressure issu...   Dec 11 2018, 09:35 AM
Jamie   I'm starting to think its a fuel pressure iss...   Dec 11 2018, 10:46 AM
Tdskip   Please do!   Dec 11 2018, 09:36 AM
wndsrfr   I'm betting on the points....   Dec 11 2018, 09:51 AM
ericoneal   Stuttgart Specialists, here in Louisville.   Dec 11 2018, 11:54 AM
Tdskip   Any news?   Dec 13 2018, 03:17 PM
ericoneal   So as suspected all along, the problem would turn ...   Dec 17 2018, 09:31 AM
VaccaRabite   So as suspected all along, the problem would turn...   Dec 17 2018, 09:57 AM
dr914@autoatlanta.com   I would say that it blew out a galley plug to spil...   Dec 17 2018, 09:58 AM
Tdskip   Glad she is running well, at least that is sort it...   Dec 17 2018, 10:00 AM
rhodyguy   With all the cranking, peddle pushing and fuel squ...   Dec 17 2018, 10:11 AM
ericoneal   I drained the two quarts that were left and put in...   Dec 17 2018, 10:15 AM
rhodyguy   You'll know whether it's a galley plug or ...   Dec 17 2018, 11:14 AM
ericoneal   Checking back in, have a look at this: Finally go...   Dec 30 2018, 07:08 PM
injunmort   there are no shims behind the seal. that's wha...   Dec 30 2018, 07:46 PM
wndsrfr   there are no shims behind the seal. that's wh...   Dec 30 2018, 08:01 PM
914_teener   there are no shims behind the seal. that's wh...   Dec 31 2018, 12:21 PM
ericoneal   It must be shim remains because the seal spring is...   Dec 30 2018, 08:12 PM
914_teener   It must be shim remains because the seal spring i...   Dec 31 2018, 01:59 PM
injunmort   if that is in fact shim remains, it was installed ...   Dec 31 2018, 01:05 PM
ericoneal   Hard question to answer. I dont know where the sh...   Dec 31 2018, 01:22 PM
injunmort   I am going to pull the flywheel off another motor ...   Dec 31 2018, 01:46 PM
injunmort   this engine has three shims behind the oil seal. I...   Dec 31 2018, 02:13 PM
ericoneal   Yeah, I'm with you on all of that. Just conce...   Dec 31 2018, 02:45 PM
injunmort   install the flywheel. measure endplay and order 3 ...   Dec 31 2018, 03:41 PM
euro911   Here ya go, Eric ... everything you need to know t...   Dec 31 2018, 04:36 PM
ericoneal   THanks, will check that out. I've actually wa...   Dec 31 2018, 08:37 PM
cgnj   That doesn't look like enough material for 3 s...   Jan 1 2019, 10:37 AM
wndsrfr   That doesn't look like enough material for 3 ...   Jan 1 2019, 12:17 PM
ericoneal   Hi all, still working on this and finally have the...   Jan 8 2019, 08:02 AM
IronHillRestorations   I only use Sabo rear main seals Eric. They are th...   Jan 8 2019, 08:31 AM
76-914   I only use Sabo rear main seals Eric. They are t...   Jan 8 2019, 09:32 AM
ericoneal   Have the seal, need the shims   Jan 8 2019, 08:33 AM
ericoneal   FYI for anyone reading this, found them here: the...   Jan 8 2019, 09:01 AM
worn   FYI for anyone reading this, found them here: th...   Jan 8 2019, 10:21 AM
ericoneal   Good thinking. I will double check the surface to...   Jan 8 2019, 10:32 AM
rhodyguy   Expensive at $12?   Jan 8 2019, 11:27 AM
- Lo-Fi Version Time is now: 28th September 2026 - 01:39 AM
