Alternator light question, concerned about a voltage drop an alternator light starting to come on |
DRPHIL914 |
Nov 16 2018, 05:25 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I am about three hours into a 5 Hour Dr. on my way to Atlanta I just noticed a little while ago maybe 10 minutes ago a slight dim Flickr or glow from my alternator light also then looking at my voltage gauge which with my lights on normal he reads 11.5 V but it now reads 10.5 phones. Also at one point I hit a bump and the light disappeared in the voltage went back up to 11.5 but then after a few minutes the voltage drop again and the light is now on very faintly but it is so here’s my question what is the most likely cause is it a loose wire somewhere is it a loose belt those are the two most likely scenarios to me but if it’s a wire what should I look for I know I’m going to have to stop to look and right now I hit a bump** edited** as I’m driving right now and the light went out . So what light is most likely loose and causing this issue I’m going to have to stop and figure it out I guess thank you for the SAP help and responses in advance, Dr. Phil
I think you can see from this picture the light is on when I turn the other lights off you can see the faint glow of the alternator light and maybe even a little bit and the other picture with the lights on Attached thumbnail(s) |
DRPHIL914 |
Nov 26 2018, 07:05 PM
iam going to do this tomorrow. i just took the car out for a spin, been sitting on battery maintainer for 2 weeks and was at 13.5 or so before starting it ans was at 12.4 running, and tdrove over to the autozone and their tester says 12.4, voltage reulator and or diode failed. i realize its probably not the regulator and probably my ground so an additional ground should do the trick. if not then the alternator will be returned in short order .
Lo-Fi Version | Time is now: 7th June 2024 - 02:24 AM |
