porsche-tom |
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None ![]() |
I am going to be changing my clutch on my 72 1.7 soon. I have read up on it and it looks to be straight forward. I was wondering if it would be worth it to just drop the whole engine? any tips from past experience would be appreciated also!
scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
I'm at this point too, actually changing to what should be a better shifting transmission and figure I might as well do the clutch while I'm at it.
How high does the car need to go? Better to leave the front tires on the ground or up on 4 jack stands? |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
I'm at this point too, actually changing to what should be a better shifting transmission and figure I might as well do the clutch while I'm at it. How high does the car need to go? Better to leave the front tires on the ground or up on 4 jack stands? For just the trans, I typically just jack up the rear and leave the front wheels on ground. You just need to get it high enough to pull the trans out from under it. Going higher just means you have to have a taller jack to lower the trans. I like to loosen the bolts on the cross bar to lower the front of the engine a bit. Then remove the bolts on the trans and lower so that it clears the trans bolts. then support the engine at that angel. Makes removal and installing a bit easier. |
Lo-Fi Version | Time is now: 11th July 2025 - 01:22 PM |
