| DRPHIL914 |
Dec 3 2018, 08:02 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
so i realized that my front shock inserts are close to 20 years old according to previous owner records and i didnt replace them when i did my rear suspension upgrade . I have sprt bilistein in rear with stock sway bar and 100# springs, pretty stiff compared to front now and 5 lug fuchs, 205/55-16’s front and rear.
when i did the new front bushings etc and the turbo tierods i did the stock calipers and drilled 5 lug stock rotors from PMB , but left the strut inserts alone, but now 3-4 years later i can see one side is about 1/2” lower tto so before getting into the alignment proceedure i figured its time to get new struts inserts so, what brand ? and who has the best deal? leaning toward bilisteins too but what is the proper part number? and should they be “sport” to match rear? i have stock sway bar and will be putting on the new Tarrett drop links i got from group buy at Okteenerfest |
| DRPHIL914 |
Dec 3 2018, 08:24 AM
these?
Attached thumbnail(s) |
| mepstein |
Dec 3 2018, 08:26 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
these? yes Drive them a couple miles before you get them aligned. It gives them a chance to settle in a bit. Doesn't need to be much. Leave on the rears for now and see how you like the ride. New front shocks make a big difference. You will love the ride and wonder why you didn't do it sooner. |
DRPHIL914 looking for advice on front shock insert replacement Dec 3 2018, 08:02 AM
mepstein I would do Bilstein HD all around. The sports are ... Dec 3 2018, 08:03 AM
DRPHIL914 so take the yellow sport B’s off rear and sell ... Dec 3 2018, 08:05 AM
DRPHIL914 looks like the #001127 is HD and 34 is regular?
t... Dec 3 2018, 08:54 AM
Mblizzard I am a fan of the Bilsteins but the adjustable Kon... Dec 3 2018, 03:40 PM
dr914@autoatlanta.com do not mix shocks, Bilstein for the front
so i ... Dec 3 2018, 03:51 PM
Dave_Darling Note that the ride height is generally set by the ... Dec 3 2018, 06:58 PM
Note that the ride height is generally set by the... Dec 3 2018, 07:40 PM
DRPHIL914
Note that the ride height is generally set by th... Dec 3 2018, 11:58 PM
euro911 Phil, adjusting the ride height is a pretty easy t... Dec 4 2018, 01:22 AM
rudedude I believe to truly set up your car it needs to be ... Dec 4 2018, 06:28 AM
DRPHIL914
Phil, adjusting the ride height is a pretty easy ... Dec 4 2018, 07:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:22 AM |
