| Tdskip |
Dec 3 2018, 07:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI. Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf. Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why? BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community. Thanks! |
| saigon71 |
Dec 3 2018, 02:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
Thanks for the discussion and all the super helpful information. Let me double check what is actually in the ar and then report back. After that I imagine it is time to start testing components before doing a swap. I know my 1.8 injectors are likely skunked.... I've got 5 nice 1.8 injectors for sale if you are interested: http://www.914world.com/bbs2/index.php?sho...=334110&hl= |
Tdskip 2.0l engine with 1.8 heads - what FI set up to use? Dec 3 2018, 07:39 AM
914Sixer For me, I would go with pieces from a bus engine. ... Dec 3 2018, 07:49 AM
Tdskip
For me, I would go with pieces from a bus engine.... Dec 3 2018, 08:18 AM
TheCabinetmaker 2.0 intake tubes and throttle body will not fit in... Dec 3 2018, 08:13 AM
Tdskip
2.0 intake tubes and throttle body will not fit i... Dec 3 2018, 08:26 AM
TheCabinetmaker I'll let the ljet experts answer that Dec 3 2018, 08:31 AM
Tdskip
Thank... Dec 3 2018, 08:41 AM
Mark Henry I've built a 2.0 head 2056 engine with Ljet, I... Dec 3 2018, 08:55 AM
Mark Henry Only power loss will be because of the 1.8 vs 2.0 ... Dec 3 2018, 08:57 AM
Tdskip
Only power loss will be because of the 1.8 vs 2.0... Dec 3 2018, 09:06 AM
Yasha7fold
Only power loss will be because of the 1.8 vs 2.0... Dec 7 2018, 08:54 PM
Mark Henry
Only power loss will be because of the 1.8 vs 2.... Dec 7 2018, 10:32 PM
TheCabinetmaker Like i said before, not without modification. Dec 3 2018, 09:09 AM
Tdskip
... Dec 3 2018, 09:21 AM
dr914@autoatlanta.com If that is all you have, use the 1.8 fuel injectio... Dec 3 2018, 09:29 AM
914Sixer Bus intake runners are 4 bolt vs 914 3 bolt, so th... Dec 3 2018, 09:31 AM
Tdskip OK - so intake runners are different. Got it.
It ... Dec 3 2018, 09:36 AM
914_teener For 1.8 heads you will need to have a hole machine... Dec 3 2018, 10:21 AM
Tdskip Thanks Rob.
So bus runners, or drill the head for... Dec 3 2018, 10:32 AM
marksteinhilber OK, so your running a 2.0 L case which tells me yo... Dec 3 2018, 10:49 AM
TheCabinetmaker The 1.7\1.8 runners are longer and don't ... Dec 3 2018, 10:53 AM
Tdskip
The 1.7\1.8 runners are longer and don't... Dec 3 2018, 10:57 AM
Mark Henry
The 1.7\1.8 runners are longer and don't... Dec 6 2018, 09:19 AM
TheCabinetmaker Bus runners are 1.8 runners. Still won't fit 2... Dec 3 2018, 10:59 AM
Valy The 2.0 and 1.8 injections are different in all pa... Dec 3 2018, 10:59 AM
Valy BTW, I forgot to mention that if you want to use t... Dec 3 2018, 11:05 AM
Tdskip Thanks for the discussion and all the super helpfu... Dec 3 2018, 12:17 PM
Dave_Darling I would go with the L-jet setup, for the reasons a... Dec 3 2018, 07:12 PM
Tdskip Thanks Dave, and all. Great discussion and very he... Dec 3 2018, 08:03 PM
cgnj Didn't this discussion happen within the last ... Dec 4 2018, 12:36 AM
ClayPerrine Use the L-system as is will get you a good running... Dec 4 2018, 06:22 AM
Valy
Use the L-system as is will get you a good runnin... Dec 4 2018, 02:43 PM
914_teener
Use the L-system as is will get you a good runni... Dec 4 2018, 04:04 PM
Tdskip Thanks gentlemen Dec 4 2018, 07:27 AM
ClayPerrine I dug out my old paper manuals from the 1980s when... Dec 5 2018, 07:24 AM
Tdskip Great info, thanks.
EDIT: I took the lead from Cl... Dec 5 2018, 07:58 AM
ClayPerrine
Great info, thanks.
EDIT: I took the lead from C... Dec 6 2018, 03:21 PM
Tdskip Thanks Mark (and gentlemen).
It will be a couple... Dec 6 2018, 09:32 AM
Tdskip Only working off feel right now but this car feels... Dec 7 2018, 09:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:28 PM |
