| Tdskip |
Dec 3 2018, 07:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI. Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf. Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why? BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community. Thanks! |
| Dave_Darling |
Dec 3 2018, 07:12 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I would go with the L-jet setup, for the reasons above. It can cope with the larger displacement, and probably will not need nearly as much tweaking to work as the D-jet will. D-jet makes more assumptions about the engine's air needs than L-jet does, as L-jet directly measures the air coming in.
Since you would be using 1.8 heads, use the 1.8 intake parts. They are made to go together, so it's a total no-brainer. The 2.0 plenum (the intake manifold box thing) is wider than the 1.8's is, so the intake runner pipes for the 2.0 are shorter. There is the different bolt pattern, as mentioned several times. Both of those can be dealt with one way or another, but they are things you have to be aware of. It would be interesting to fit the L-jet's air flow meter onto a 2.0 throttle body; different ducting would be needed and the 912E parts (which use L-jet on a 2.0 914 motor) are hard to come by. The L-jet and D-jet injectors are operated differently (D-jet supplies power to open them; L-jet supplies a ground to open the injectors) and I think may use different power levels and have different impedance. I recall the late Cap'n Krusty telling us that the Bosch reps cautioned to never switch L-jet and D-jet injectors, as that could cause some electrical issues and possibly even fry something. So: Use the L-jet, complete. It fits what you have, and it should cope with the larger displacement just fine. No mix-and-match of parts required, no machining required, just bolt it all together. (And spend however long it takes to fix all of your vacuum leaks!) --DD |
Tdskip 2.0l engine with 1.8 heads - what FI set up to use? Dec 3 2018, 07:39 AM
914Sixer For me, I would go with pieces from a bus engine. ... Dec 3 2018, 07:49 AM
Tdskip
For me, I would go with pieces from a bus engine.... Dec 3 2018, 08:18 AM
TheCabinetmaker 2.0 intake tubes and throttle body will not fit in... Dec 3 2018, 08:13 AM
Tdskip
2.0 intake tubes and throttle body will not fit i... Dec 3 2018, 08:26 AM
TheCabinetmaker I'll let the ljet experts answer that Dec 3 2018, 08:31 AM
Tdskip
Thank... Dec 3 2018, 08:41 AM
Mark Henry I've built a 2.0 head 2056 engine with Ljet, I... Dec 3 2018, 08:55 AM
Mark Henry Only power loss will be because of the 1.8 vs 2.0 ... Dec 3 2018, 08:57 AM
Tdskip
Only power loss will be because of the 1.8 vs 2.0... Dec 3 2018, 09:06 AM
Yasha7fold
Only power loss will be because of the 1.8 vs 2.0... Dec 7 2018, 08:54 PM
Mark Henry
Only power loss will be because of the 1.8 vs 2.... Dec 7 2018, 10:32 PM
TheCabinetmaker Like i said before, not without modification. Dec 3 2018, 09:09 AM
Tdskip
... Dec 3 2018, 09:21 AM
dr914@autoatlanta.com If that is all you have, use the 1.8 fuel injectio... Dec 3 2018, 09:29 AM
914Sixer Bus intake runners are 4 bolt vs 914 3 bolt, so th... Dec 3 2018, 09:31 AM
Tdskip OK - so intake runners are different. Got it.
It ... Dec 3 2018, 09:36 AM
914_teener For 1.8 heads you will need to have a hole machine... Dec 3 2018, 10:21 AM
Tdskip Thanks Rob.
So bus runners, or drill the head for... Dec 3 2018, 10:32 AM
marksteinhilber OK, so your running a 2.0 L case which tells me yo... Dec 3 2018, 10:49 AM
TheCabinetmaker The 1.7\1.8 runners are longer and don't ... Dec 3 2018, 10:53 AM
Tdskip
The 1.7\1.8 runners are longer and don't... Dec 3 2018, 10:57 AM
Mark Henry
The 1.7\1.8 runners are longer and don't... Dec 6 2018, 09:19 AM
TheCabinetmaker Bus runners are 1.8 runners. Still won't fit 2... Dec 3 2018, 10:59 AM
Valy The 2.0 and 1.8 injections are different in all pa... Dec 3 2018, 10:59 AM
Valy BTW, I forgot to mention that if you want to use t... Dec 3 2018, 11:05 AM
Tdskip Thanks for the discussion and all the super helpfu... Dec 3 2018, 12:17 PM
saigon71
Thanks for the discussion and all the super helpf... Dec 3 2018, 02:24 PM
Tdskip Thanks Dave, and all. Great discussion and very he... Dec 3 2018, 08:03 PM
cgnj Didn't this discussion happen within the last ... Dec 4 2018, 12:36 AM
ClayPerrine Use the L-system as is will get you a good running... Dec 4 2018, 06:22 AM
Valy
Use the L-system as is will get you a good runnin... Dec 4 2018, 02:43 PM
914_teener
Use the L-system as is will get you a good runni... Dec 4 2018, 04:04 PM
Tdskip Thanks gentlemen Dec 4 2018, 07:27 AM
ClayPerrine I dug out my old paper manuals from the 1980s when... Dec 5 2018, 07:24 AM
Tdskip Great info, thanks.
EDIT: I took the lead from Cl... Dec 5 2018, 07:58 AM
ClayPerrine
Great info, thanks.
EDIT: I took the lead from C... Dec 6 2018, 03:21 PM
Tdskip Thanks Mark (and gentlemen).
It will be a couple... Dec 6 2018, 09:32 AM
Tdskip Only working off feel right now but this car feels... Dec 7 2018, 09:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:46 PM |
