| Highland |
Dec 4 2018, 05:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So I'm at the stage where I'm going to drop the brakes and suspension to change bearings, bushings, calipers, rotors, pads, shocks, springs, etc. I plan to start with the rear then move to the front.
So the car will probably be off its wheels for some time while I'm trying to figure this all out. I've emptied the brake reservoir with a turkey baster, but of course there's still fluid in the lines. I'm also thinking it would be easier to bleed the lines if there's fluid in them. My question is where is the best place to disconnect the brake lines (before or after the flex) and what's the best way to cap it so I don't end up with brake fluid on my paint? |
| mepstein |
Dec 4 2018, 06:16 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,022 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Clamp the flex line closed and remove it at the flex/hard line junction. Put the flex line in a bottle, unclamp and let drain. Replace flex line if you can’t remember the last time it was changed. Flex lines fail when they get old.
Highland How to Cap the Brakes Lines for Staging Dec 4 2018, 05:05 PM
jcd914 I have a mix of plastic threaded plugs and ends of... Dec 5 2018, 04:39 PM
cary
ends of old brake lines that have been cut off an... Dec 9 2018, 09:21 AM
BillC Unbolt the hard line from the caliper and then put... Dec 5 2018, 04:47 PM
Unbolt the hard line from the caliper and then pu... Dec 5 2018, 04:58 PM
BillC Also replace the fluid it absorbs water over time,... Dec 5 2018, 07:25 PM
rgalla9146 A simple way to stop leakage when doing open brake... Dec 5 2018, 05:51 PM
914forme :agree:
If it is going to be setting a long time,... Dec 5 2018, 07:00 PM
Highland Thanks for all the good ideas.
I was planning on ... Dec 6 2018, 10:51 AM
ChrisFoley You don't need to replace the hard lines unles... Dec 6 2018, 11:12 AM
PlaysWithCars
... put a vacuum cap over the end of the line. Q... Dec 6 2018, 11:50 PM
90quattrocoupe Over the years of going to junkyards for the vario... Dec 9 2018, 01:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 10:51 AM |
