> 2.0l engine with 1.8 heads - what FI set up to use?
Tdskip
post Dec 3 2018, 07:39 AM
Counter to popular belief I do not stay up late inventing hairbrained questions for you all, although that is tempting sometime given the wealth of knowledge here. As of around 10:30 AM today this will be a real life scenario.
Let’s imagine I have a 2.0l case running 1.8 heads with a single Weber that runs but I want to convert back to FI.
Let’s further image that I have both a 1.8 FI set up and a 2.0 FI set up sitting in the shelf.
Which FI set up would I be best advised to use on this engine, and for bonus points and adding to the community knowledge here, why?
BTW - planning on doing a tech day on this with/for the SoCal mafia once I get a plan together. Given what seems to be a trend back to FI (or at least renewed interest) I think it could be a useful tech day for the community.
Thanks!
ClayPerrine
post Dec 5 2018, 07:24 AM
I dug out my old paper manuals from the 1980s when I worked for VW in Fort Worth.
914 1.8 PET part number 022906031C
Bosch EV1 Fuel Injector
pintle nozzle
Flow rates @ 41.5 psi / 3 bar
17 lb per hour
178.5 cc per min
2.4 Ohm resistance
Bosch # 0280150112
Volkswagen # 022906031C
912E PET part number 92360610900
pintle nozzle
Flow rates @ 43.5 psi / 3 bar
19 lb per hour
199.4 cc per min
2.4 Ohm resistance
Bosch # 0280150105
Fiat # 6052340
Porsche # 92360610900
Peugeot # 7700582691
Jaguar # EAC3620
Volkswagen # 022906031D
The 914 1.8L injector is VW number 022906031C and the 912E injector is VW number 022906031D. What you are seeing is the current listings offered by the dealerships and parts suppliers. It is the standard superseding process that goes on with all car manufactures. The eliminate what they consider "duplicate" inventory to cut replacement parts costs. If you use an original 914 1.8 injector, you don't get the same fuel flow as a 912E injector. If you buy new, you will get the 912E injector even if you want a 914 1.8 injector. The 914 1.8 injector was discontinued.
So basically, you and I are both right. The currently available injectors for a 1.8L 914 are the same as a 912E. But it didn't start out that way.
Tdskip   2.0l engine with 1.8 heads - what FI set up to use?   Dec 3 2018, 07:39 AM
914Sixer   For me, I would go with pieces from a bus engine. ...   Dec 3 2018, 07:49 AM
Tdskip   For me, I would go with pieces from a bus engine....   Dec 3 2018, 08:18 AM
TheCabinetmaker   2.0 intake tubes and throttle body will not fit in...   Dec 3 2018, 08:13 AM
Tdskip   2.0 intake tubes and throttle body will not fit i...   Dec 3 2018, 08:26 AM
TheCabinetmaker   I'll let the ljet experts answer that   Dec 3 2018, 08:31 AM
Tdskip   I'll let the ljet experts answer that Thank...   Dec 3 2018, 08:41 AM
Mark Henry   I've built a 2.0 head 2056 engine with Ljet, I...   Dec 3 2018, 08:55 AM
Mark Henry   Only power loss will be because of the 1.8 vs 2.0 ...   Dec 3 2018, 08:57 AM
Tdskip   Only power loss will be because of the 1.8 vs 2.0...   Dec 3 2018, 09:06 AM
Yasha7fold   Only power loss will be because of the 1.8 vs 2.0...   Dec 7 2018, 08:54 PM
Mark Henry   Only power loss will be because of the 1.8 vs 2....   Dec 7 2018, 10:32 PM
TheCabinetmaker   Like i said before, not without modification.   Dec 3 2018, 09:09 AM
Tdskip   Like i said before, not without modification. ...   Dec 3 2018, 09:21 AM
dr914@autoatlanta.com   If that is all you have, use the 1.8 fuel injectio...   Dec 3 2018, 09:29 AM
914Sixer   Bus intake runners are 4 bolt vs 914 3 bolt, so th...   Dec 3 2018, 09:31 AM
Tdskip   OK - so intake runners are different. Got it. It ...   Dec 3 2018, 09:36 AM
914_teener   For 1.8 heads you will need to have a hole machine...   Dec 3 2018, 10:21 AM
Tdskip   Thanks Rob. So bus runners, or drill the head for...   Dec 3 2018, 10:32 AM
marksteinhilber   OK, so your running a 2.0 L case which tells me yo...   Dec 3 2018, 10:49 AM
TheCabinetmaker   The 1.7\1.8 runners are longer and don't ...   Dec 3 2018, 10:53 AM
Tdskip   The 1.7\1.8 runners are longer and don't...   Dec 3 2018, 10:57 AM
Mark Henry   The 1.7\1.8 runners are longer and don't...   Dec 6 2018, 09:19 AM
TheCabinetmaker   Bus runners are 1.8 runners. Still won't fit 2...   Dec 3 2018, 10:59 AM
Valy   The 2.0 and 1.8 injections are different in all pa...   Dec 3 2018, 10:59 AM
Valy   BTW, I forgot to mention that if you want to use t...   Dec 3 2018, 11:05 AM
Tdskip   Thanks for the discussion and all the super helpfu...   Dec 3 2018, 12:17 PM
saigon71   Thanks for the discussion and all the super helpf...   Dec 3 2018, 02:24 PM
Dave_Darling   I would go with the L-jet setup, for the reasons a...   Dec 3 2018, 07:12 PM
Tdskip   Thanks Dave, and all. Great discussion and very he...   Dec 3 2018, 08:03 PM
cgnj   Didn't this discussion happen within the last ...   Dec 4 2018, 12:36 AM
ClayPerrine   Use the L-system as is will get you a good running...   Dec 4 2018, 06:22 AM
Valy   Use the L-system as is will get you a good runnin...   Dec 4 2018, 02:43 PM
914_teener   Use the L-system as is will get you a good runni...   Dec 4 2018, 04:04 PM
Tdskip   Thanks gentlemen   Dec 4 2018, 07:27 AM
ClayPerrine   I dug out my old paper manuals from the 1980s when...   Dec 5 2018, 07:24 AM
Tdskip   Great info, thanks. EDIT: I took the lead from Cl...   Dec 5 2018, 07:58 AM
ClayPerrine   Great info, thanks. EDIT: I took the lead from C...   Dec 6 2018, 03:21 PM
Tdskip   Thanks Mark (and gentlemen). It will be a couple...   Dec 6 2018, 09:32 AM
Tdskip   Only working off feel right now but this car feels...   Dec 7 2018, 09:03 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:00 PM
