| ericoneal |
Nov 26 2018, 07:56 AM
Member ![]() ![]() Group: Members Posts: 327 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
| mobymutt |
Dec 6 2018, 01:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Are you sure the firing order is correct? My car initially had plugged up carbs, timing off and not well synced, and the thing still ran (not well, but it ran). Only time I had symptoms like yours was when I switched the plug wires around.
| wndsrfr |
Dec 6 2018, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,467 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Are you sure the firing order is correct? My car initially had plugged up carbs, timing off and not well synced, and the thing still ran (not well, but it ran). Only time I had symptoms like yours was when I switched the plug wires around. (IMG:style_emoticons/default/agree.gif) However, I have seen a situation where the points rubbing block had worn entirely down due to no lube so the points were not really opening at all...be sure that they are actually breaking contact...check it with a test light, easy to do. |
ericoneal Wont start Nov 26 2018, 07:56 AM
dr914@autoatlanta.com check the dwell angle and make sure it is good at ... Nov 26 2018, 09:19 AM
ericoneal Pretty sure the coil is wired correctly, I took pi... Nov 26 2018, 10:29 AM
Mblizzard Because the Tach draws its signal from the coil, I... Nov 26 2018, 12:08 PM
Tdskip If you didn't move the distributor when the en... Nov 26 2018, 12:16 PM
IronHillRestorations Spark, air, fuel, compression. It's one of th... Nov 26 2018, 01:52 PM
ericoneal Still no luck, here is what I did:
1. I checked ... Nov 26 2018, 08:11 PM
Tdskip That sounds like a P-51 Merlin warming up.
Seems ... Nov 26 2018, 10:09 PM
second wind I lost three months of run time with my car due to... Nov 26 2018, 11:13 PM
Mblizzard I have o say its fuel as well.
Do the standard sp... Nov 27 2018, 08:03 AM
ericoneal I sprayed fluid in the carbs and it fires up easie... Nov 27 2018, 08:36 AM
mobymutt
I sprayed fluid in the carbs and it fires up easi... Nov 27 2018, 09:16 AM
rhodyguy Is it possible to maintain 2.7-3k rpm with a stead... Nov 27 2018, 08:52 AM
IronHillRestorations How long did it sit? My guess is the fuel that wa... Nov 27 2018, 09:50 AM
ericoneal Sent the video to a local guy here who is very goo... Nov 27 2018, 11:54 AM
Mblizzard
Sent the video to a local guy here who is very go... Nov 27 2018, 12:19 PM
ericoneal Its a single hexbar between the two. Pretty sure ... Nov 27 2018, 12:20 PM
Tdskip You should be able to disconnect the bar and set e... Nov 27 2018, 12:26 PM
Mblizzard
You should be able to disconnect the bar and set ... Nov 27 2018, 12:31 PM
TheCabinetmaker Sounds like the engine is fighting itself to run f... Nov 28 2018, 11:55 AM
Triaddave It may sound stupid but maybe a kinked fuel line o... Nov 28 2018, 12:12 PM
marksteinhilber You have unsteady firing from a number of cylinder... Nov 28 2018, 02:09 PM
ericoneal I will double check the spark tonight by pulling t... Nov 28 2018, 03:35 PM
cgnj
I will double check the spark tonight by pulling ... Nov 29 2018, 05:05 AM
sdoolin Watched the video also. I think you have a linkage... Nov 29 2018, 07:33 AM
ericoneal Thats why this website is great. PMed received, w... Nov 29 2018, 11:30 AM
Mblizzard
Thats why this website is great. PMed received, ... Nov 29 2018, 12:10 PM
Tdskip Making progress....please keep us posted and someo... Nov 29 2018, 01:50 PM
ericoneal I got it covered..
Making progress....please kee... Nov 29 2018, 03:35 PM
cgnj post a pic of your carbs and linkage as they are c... Nov 30 2018, 05:18 AM
ericoneal sdoolin rolled over this afternoon in his great lo... Nov 30 2018, 09:26 PM
wndsrfr
sdoolin rolled over this afternoon in his great l... Dec 1 2018, 07:21 AM
sdoolin As Eric said, not a fuel issue. We removed and cle... Dec 1 2018, 09:02 AM
Tdskip Well - look at it this way, the carb work sounds l... Dec 1 2018, 09:54 AM
cgnj basics 101
At this point, I would jack it jp put ... Dec 1 2018, 11:23 AM
injunmort do you have access to a timing light? how are you ... Dec 1 2018, 01:29 PM
ericoneal
do you have access to a timing light? how are you... Dec 1 2018, 01:34 PM
injunmort yes, there is more to it than that. are you runnin... Dec 6 2018, 09:27 AM
ericoneal Thanks, I'm familar with timing the engine onc... Dec 6 2018, 09:48 AM
injunmort you must make sure points are opening when you set... Dec 6 2018, 12:50 PM
rhodyguy Try turning the idle up using ONE idle speed adjus... Dec 6 2018, 01:25 PM
Rand I haven't read the whole thread. But you know ... Dec 6 2018, 05:11 PM
Spoke In the video, your first key turn resulted in the ... Dec 7 2018, 06:48 PM
Tdskip
In the video, your first key turn resulted in the... Dec 7 2018, 08:39 PM
second wind For $50 I would buy a new coil to totally eli... Dec 7 2018, 07:20 PM
Rand Coils have a VERY low failure rate. Test first. Dec 7 2018, 08:35 PM
ericoneal I got the new starter on today, so at least I am b... Dec 7 2018, 09:15 PM
Tdskip 0.016", same as any other 914 or Type IV moto... Dec 8 2018, 01:56 AM
mobymutt Maybe post some pictures of the wires, distributer... Dec 8 2018, 01:57 PM
ericoneal Tested the coil and am getting a strong white spar... Dec 9 2018, 10:36 AM
cgnj
Tested the coil and am getting a strong white spa... Dec 9 2018, 11:30 AM
Spoke The item on the side of the distributor is the vac... Dec 9 2018, 10:48 AM
ericoneal Tried that too. At this point just going through ... Dec 9 2018, 11:08 AM
Spoke
Tried that too.
OK, so you sprayed starting flu... Dec 9 2018, 11:46 AM
cuddy_k I’m thinking fuel as well. Could be that the pum... Dec 9 2018, 11:14 AM
ericoneal After spraying, it takes a few times, then starts ... Dec 9 2018, 11:50 AM
Spoke
After spraying, it takes a few times, then starts... Dec 9 2018, 12:32 PM
euro911 Have you checked the fuel pressure at the carb... Dec 9 2018, 02:49 PM
injunmort you have still not timed it. yes the distributor a... Dec 9 2018, 02:54 PM
tom.esh How old is the gas in the tank? Could it just be b... Dec 9 2018, 03:03 PM
Tdskip Bump for an update and any help needed to get you ... Dec 11 2018, 08:21 AM
ericoneal I'm starting to think its a fuel pressure issu... Dec 11 2018, 09:35 AM
Jamie
I'm starting to think its a fuel pressure iss... Dec 11 2018, 10:46 AM
Tdskip Please do! Dec 11 2018, 09:36 AM
wndsrfr I'm betting on the points.... Dec 11 2018, 09:51 AM
ericoneal Stuttgart Specialists, here in Louisville. Dec 11 2018, 11:54 AM
Tdskip Any news? Dec 13 2018, 03:17 PM
ericoneal So as suspected all along, the problem would turn ... Dec 17 2018, 09:31 AM
VaccaRabite
So as suspected all along, the problem would turn... Dec 17 2018, 09:57 AM
dr914@autoatlanta.com I would say that it blew out a galley plug to spil... Dec 17 2018, 09:58 AM
Tdskip Glad she is running well, at least that is sort it... Dec 17 2018, 10:00 AM
rhodyguy With all the cranking, peddle pushing and fuel squ... Dec 17 2018, 10:11 AM
ericoneal I drained the two quarts that were left and put in... Dec 17 2018, 10:15 AM
rhodyguy You'll know whether it's a galley plug or ... Dec 17 2018, 11:14 AM
ericoneal Checking back in, have a look at this:
Finally go... Dec 30 2018, 07:08 PM
injunmort there are no shims behind the seal. that's wha... Dec 30 2018, 07:46 PM
wndsrfr
there are no shims behind the seal. that's wh... Dec 30 2018, 08:01 PM
914_teener
there are no shims behind the seal. that's wh... Dec 31 2018, 12:21 PM
ericoneal It must be shim remains because the seal spring is... Dec 30 2018, 08:12 PM
914_teener
It must be shim remains because the seal spring i... Dec 31 2018, 01:59 PM
injunmort if that is in fact shim remains, it was installed ... Dec 31 2018, 01:05 PM
ericoneal Hard question to answer. I dont know where the sh... Dec 31 2018, 01:22 PM
injunmort I am going to pull the flywheel off another motor ... Dec 31 2018, 01:46 PM
injunmort this engine has three shims behind the oil seal. I... Dec 31 2018, 02:13 PM
ericoneal Yeah, I'm with you on all of that. Just conce... Dec 31 2018, 02:45 PM
injunmort install the flywheel. measure endplay and order 3 ... Dec 31 2018, 03:41 PM
euro911 Here ya go, Eric ... everything you need to know t... Dec 31 2018, 04:36 PM
ericoneal THanks, will check that out. I've actually wa... Dec 31 2018, 08:37 PM
cgnj That doesn't look like enough material for 3 s... Jan 1 2019, 10:37 AM
wndsrfr
That doesn't look like enough material for 3 ... Jan 1 2019, 12:17 PM
ericoneal Hi all, still working on this and finally have the... Jan 8 2019, 08:02 AM
IronHillRestorations I only use Sabo rear main seals Eric. They are th... Jan 8 2019, 08:31 AM
76-914
I only use Sabo rear main seals Eric. They are t... Jan 8 2019, 09:32 AM
ericoneal Have the seal, need the shims Jan 8 2019, 08:33 AM
ericoneal FYI for anyone reading this, found them here:
the... Jan 8 2019, 09:01 AM
worn
th... Jan 8 2019, 10:21 AM
ericoneal Good thinking. I will double check the surface to... Jan 8 2019, 10:32 AM
rhodyguy Expensive at $12? Jan 8 2019, 11:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 01:39 AM |
