Clutch Cable Wisdom Requested, What should the feel feel like? |
ctc911ctc |
Dec 3 2018, 05:58 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Hi,
I have the silver bullet ('74 2.0 - garaged since '84, just purchased and refreshed - lots of welding) running and I do not like the clutch feel. In my past 914s, the clutch feel was a lot of pressure for the first 1/2 of the pedal travel and then the pressure nearly went away once the pedal traveled close to the floor. This cars clutch is stiff all the way down to the floor, I believe that the top inch or two is just spring tension. I went under the car to tighten the cable and found myself wondering what the forum might say. Questions: 1. Is there a correct feel, or should all be different? 2. Though the cable looks very good (not frayed, etc) how much can they stretch? Do they stretch? 3. Any other advice on this would be helpful. Long on knowledge - Short on experience, CTC911CTC |
76-914 |
Dec 3 2018, 08:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
First, I'd remove the rear access panel on top of the tunnel, then lift and move the bundle of wires directly behind the crossbar which will allow you to see the clutch tube and finally remove the bolts at the base plate of the shifter. Now rotate the base of the shifter 90 degrees. You now can watch the clutch tube at the 3 attach points where they frequently come loose. Depress the clutch pedal several times as you watch the tube. If the tube doesn't move from side to side you're good. Now remove the 2 - 11mm nuts and pull the clutch cable loose from the clutch fork. The clutch pedal should fall to the floorboard pulling the cable with it. Pull and release the cable to see if it drags or binds. If it doesn't it isn't binding. The stiff pedal you describe could be a HD pressure plate but I doubt it. The TO bearing can bind on the pilot shaft but you'd need to drop the tranny to verify. Personally, I'd drive it a bit to see if it got better before I'd drop the tranny. (IMG:style_emoticons/default/beerchug.gif)
ctc911ctc |
Dec 10 2018, 03:56 PM
Soooo,
The clutch tubes were all attached, the cable was in good shape but the pulley assembly was completed filled with dirt cemented with grease. took off the cable at the clutch arm and the pedal dropped to the floor. Just like you said.......ahhhh Took off the clutch reverse-er assembly, cleaned, polished and lubed. Reassembled and re-installed. Hooked it up, tightened to the point of tension in the cable. Feels like a new clutch up front and more importantly my muscle memory says: yup, that's it - that is what it should feel like! Shouldn't there be a cover for this assembly? After the clutch was sorted, I moved on to the shifter which was a bit loose, seems I may need new bushings, Both of these are destroyed, also there are no parts in the shifter cup at the transmission side-shifter. Interestingly there were no parts in the cover when I removed it.....hhhhmmmm, where did they go???? There is rust on the firewall, though the mount is solid,,,,,,,,where did that bushing go???? No parts or remnants.......hhhmmmmm First, I'd remove the rear access panel on top of the tunnel, then lift and move the bundle of wires directly behind the crossbar which will allow you to see the clutch tube and finally remove the bolts at the base plate of the shifter. Now rotate the base of the shifter 90 degrees. You now can watch the clutch tube at the 3 attach points where they frequently come loose. Depress the clutch pedal several times as you watch the tube. If the tube doesn't move from side to side you're good. Now remove the 2 - 11mm nuts and pull the clutch cable loose from the clutch fork. The clutch pedal should fall to the floorboard pulling the cable with it. Pull and release the cable to see if it drags or binds. If it doesn't it isn't binding. The stiff pedal you describe could be a HD pressure plate but I doubt it. The TO bearing can bind on the pilot shaft but you'd need to drop the tranny to verify. Personally, I'd drive it a bit to see if it got better before I'd drop the tranny. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:51 AM |
