Fresh air box install video, be afraid. be very afraid |
iankarr |
Dec 9 2018, 10:28 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,477 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Had a great time with @ValcoOscar , @914-300hemi , @mike_D and @secondwind working on @914_7T3 's car yesterday and shot this video while we refurbed and installed his fresh air box. My hands still hurt, but hopefully this video helps the greater good. Shout out as always to @mikey914 and @matty900 Enjoy... https://www.youtube.com/watch?v=Uhs6pedBOXM |
iankarr |
Dec 10 2018, 07:57 PM
@rstover Interesting idea to separate the box. I wonder if that's how the factory did it? I swear, some of this stuff is like trying to figure out how the Egyptians built the pyramids.
One way to make your approach even easier would be to substitute the fan assembly bolts with threaded studs. then all you'd have to do is put the fan on and spin some nuts down. Not concours, but kudos to any judges who can get their eyeballs under the air box (IMG:style_emoticons/default/wink.gif) |
rstover |
Dec 10 2018, 08:20 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
@rstover Interesting idea to separate the box. I wonder if that's how the factory did it? I swear, some of this stuff is like trying to figure out how the Egyptians built the pyramids. One way to make your approach even easier would be to substitute the fan assembly bolts with threaded studs. then all you'd have to do is put the fan on and spin some nuts down. Not concours, but good luck getting a judges eyeballs under the air box (IMG:style_emoticons/default/wink.gif) If I had not been fighting the foam gasket and had longer bolts I think it would have been fairly easy. If I was doing it again I would make my own gasket out of cork i think. I believe it acts more of a spacer than a gasket anyway. |
Mikey914 |
Dec 10 2018, 09:14 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
@rstover Interesting idea to separate the box. I wonder if that's how the factory did it? I swear, some of this stuff is like trying to figure out how the Egyptians built the pyramids. One way to make your approach even easier would be to substitute the fan assembly bolts with threaded studs. then all you'd have to do is put the fan on and spin some nuts down. Not concours, but good luck getting a judges eyeballs under the air box (IMG:style_emoticons/default/wink.gif) If I had not been fighting the foam gasket and had longer bolts I think it would have been fairly easy. If I was doing it again I would make my own gasket out of cork i think. I believe it acts more of a spacer than a gasket anyway. Cork would be harder and yes you would definitely need longer bolts. The closed cell foam is what factory used and mine is 1/16" thicker |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:26 PM |
