> Replacing "Bracket for Hinge Pillar"
DickSteinkamp
post Dec 5 2018, 06:26 PM
I need to replace the right side Bracket for Hinge Pillar (914 501 030 10)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544055999.1.jpg)
It would be much easier if I could remove the right side Lateral Grill (914 504 012 10)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544056000.2.jpg)
How is it fastened in?
Thanks!
DickSteinkamp
post Dec 12 2018, 07:39 PM
Mission accomplished.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544665196.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1544665197.2.jpg)
We removed the Lateral Grill, the deck lid, the battery, and the old bracket. We drilled holes in the new bracket where we would plug weld it eventually. We attached the new bracket with sheet metal screws using the outline of where the old bracket was and remounted the deck lid. The deck lid was just a hair long, so we removed it again, repositioned the bracket and remounted the lid. It was then spot on. We removed the lid again and welded the bracket.
It helped that the deck lid, lateral grill and battery were out. It especially helped that my partner in crime is a MUCH better welder than I am. (IMG:style_emoticons/default/biggrin.gif)
dr914@autoatlanta.com
post Dec 13 2018, 09:07 AM
very nice, we have seen, over the years, a lot of butchery done replacing the trunk hinge bracket; glopped welds, riveted on, misplaced causing the trunk lid to be out of alignment, burnt specifications sticker, poor painting, holes burned into the inner fender wells, home made brackets, the list goes on...
QUOTE(DickSteinkamp @ Dec 12 2018, 06:39 PM) *
DickSteinkamp   Replacing "Bracket for Hinge Pillar"   Dec 5 2018, 06:26 PM
Larmo63   It has little pins, usually speed nuts on them.   Dec 5 2018, 06:28 PM
rgalla9146   Is your engine in or out ? It is much easier to do...   Dec 5 2018, 08:02 PM
TravisNeff   Is your engine in or out ? It is much easier to d...   Dec 6 2018, 08:45 AM
Costa05   Is your engine in or out ? It is much easier to d...   Dec 6 2018, 11:05 AM
bbrock   Is your engine in or out ? It is much easier to ...   Dec 6 2018, 11:22 AM
DickSteinkamp   Thanks! I think I can do it with the engine i...   Dec 6 2018, 09:44 AM
dr914@autoatlanta.com   it is easy if you know how to weld and have mcmark...   Dec 6 2018, 09:51 AM
DickSteinkamp   Thanks, George. I did get the bracket from you. ...   Dec 6 2018, 10:55 AM
DickSteinkamp   Mission accomplished. http://www.914world.com/bbs...   Dec 12 2018, 07:39 PM
dr914@autoatlanta.com   very nice, we have seen, over the years, a lot of ...   Dec 13 2018, 09:07 AM
bbrock   My hat is off to you. Well done. I know I couldn...   Dec 12 2018, 07:46 PM
Olympic 914   My hat is off to you. Well done. I know I could...   Dec 13 2018, 08:58 AM
DickSteinkamp   BTW, Thanks, Brent, for your hint on removing the ...   Dec 12 2018, 07:48 PM
IronHillRestorations   FWIW, I usually add welds to the back side on the ...   Dec 13 2018, 09:03 AM
Olympic 914   FWIW, I usually add welds to the back side on the...   Dec 13 2018, 10:05 AM
dr914@autoatlanta.com   the factory originally welded the two together and...   Dec 13 2018, 10:18 AM
IronHillRestorations   the factory originally welded the two together an...   Dec 13 2018, 12:04 PM
TravisNeff   Definitely weld the nut to the back. That is a gre...   Dec 13 2018, 09:05 AM
dr914@autoatlanta.com   some of the butchery   Dec 13 2018, 09:20 AM
dr914@autoatlanta.com   one more:   Dec 13 2018, 09:27 AM
DickSteinkamp   Yikes! Not pretty pictures. I think mine was...   Dec 13 2018, 10:38 AM
- Lo-Fi Version Time is now: 31st October 2024 - 06:10 PM
