> Fire extinguisher recommendations?, Time to replace.
mountainroads
post Dec 13 2018, 10:08 AM
This topic has probably come up before, I honestly tried the search function with several options, but couldn't find anything??
The in-cabin fire extinguisher that came with the car is up for renewal. I'm a cheap bastard at heart, but this doesn't seem like the right time to cheap out and forego a replacement, even if it's for something I hope I'll never have to use. Especially since even the "good" ones I saw were all sub-$100 (?)
I like the idea of keeping handy in the cabin instead of one of the trunks. Realize that comes with some space and mounting considerations. FWIW: My existing unit was mounted parallel to the tunnel and ahead of the shifter (no center console box). What does this esteemed knowledge base use and where/how do you mount? Thanks in advance for recommendations.
- MR
PS: Hope I'm not opening another religious debate, similar to "What's the best engine oil?" (IMG:style_emoticons/default/smile.gif)
oakdalecurtis
post Dec 13 2018, 12:14 PM
Oakdalecurtis
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues.
And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif)
mountainroads   Fire extinguisher recommendations?   Dec 13 2018, 10:08 AM
VaccaRabite   The best fire extinguisher is the one you don...   Dec 13 2018, 10:23 AM
Ansbacher   The best fire extinguisher is the one you don...   Dec 13 2018, 03:21 PM
Pursang   The cost difference between good and bad extinguis...   Dec 13 2018, 10:33 AM
oakdalecurtis   Here's my fire solution(s). I have a BlazeCut ...   Dec 13 2018, 12:14 PM
11tenths   Here's my fire solution(s). I have a BlazeCut...   Dec 13 2018, 03:40 PM
oakdalecurtis   Here's my fire solution(s). I have a BlazeCu...   Dec 13 2018, 04:28 PM
PeeGreen 914   https://extinguishstick.com/ Have you ever seen t...   Dec 13 2018, 04:26 PM
stownsen914   Same idea as https://elementfire.com/products/elem...   Dec 13 2018, 05:46 PM
Larmo63   I have the larger Industrial size Element in my ca...   Dec 13 2018, 06:56 PM
Coondog   Buy a Purple K extinguisher. You can find them on ...   Dec 13 2018, 07:40 PM
914_7T3   Buy a Purple K extinguisher. You can find them on...   May 9 2020, 12:56 PM
ndfrigi   Buy a Purple K extinguisher. You can find them o...   May 9 2020, 01:18 PM
914Toy   Buy a Purple K extinguisher. You can find them on...   May 9 2020, 02:18 PM
Coondog   [quote name='Coondog' post='2673678' date='Dec 13...   May 9 2020, 02:32 PM
914Toy   [quote name='Coondog' post='2673678' date='Dec 1...   May 9 2020, 08:19 PM
Big Len   Based on Coondog's recommendation, that's ...   Dec 13 2018, 07:47 PM
Coondog   Here is my current set up Purple K 20 B-C. Halotro...   May 9 2020, 02:28 PM
bkrantz   For many years I was an SCCA corner worker, and I ...   May 9 2020, 08:29 PM
- Lo-Fi Version Time is now: 23rd June 2026 - 01:30 PM
