| mountainroads |
Dec 13 2018, 10:08 AM
Member ![]() ![]() Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
This topic has probably come up before, I honestly tried the search function with several options, but couldn't find anything??
The in-cabin fire extinguisher that came with the car is up for renewal. I'm a cheap bastard at heart, but this doesn't seem like the right time to cheap out and forego a replacement, even if it's for something I hope I'll never have to use. Especially since even the "good" ones I saw were all sub-$100 (?) I like the idea of keeping handy in the cabin instead of one of the trunks. Realize that comes with some space and mounting considerations. FWIW: My existing unit was mounted parallel to the tunnel and ahead of the shifter (no center console box). What does this esteemed knowledge base use and where/how do you mount? Thanks in advance for recommendations. - MR PS: Hope I'm not opening another religious debate, similar to "What's the best engine oil?" (IMG:style_emoticons/default/smile.gif) |
| oakdalecurtis |
Dec 13 2018, 12:14 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,420 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues.
And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) |
| 11tenths |
Dec 13 2018, 03:40 PM
Ve get too soon old, und too late schmart ![]() ![]() Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues. And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) Kinda ironic you have a Crane "FireBall" right under your Blaze-Cut. |
| oakdalecurtis |
Dec 13 2018, 04:28 PM
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues. And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) Kinda ironic you have a Crane "FireBall" right under your Blaze-Cut. Don’t you believe in ying and yang?? (IMG:style_emoticons/default/grouphug.gif) |
mountainroads Fire extinguisher recommendations? Dec 13 2018, 10:08 AM
VaccaRabite The best fire extinguisher is the one you don... Dec 13 2018, 10:23 AM
Ansbacher
The best fire extinguisher is the one you don... Dec 13 2018, 03:21 PM
Pursang The cost difference between good and bad extinguis... Dec 13 2018, 10:33 AM
PeeGreen 914 https://extinguishstick.com/
Have you ever seen t... Dec 13 2018, 04:26 PM
stownsen914 Same idea as https://elementfire.com/products/elem... Dec 13 2018, 05:46 PM
Larmo63 I have the larger Industrial size Element in my ca... Dec 13 2018, 06:56 PM
Coondog Buy a Purple K extinguisher. You can find them on ... Dec 13 2018, 07:40 PM
914_7T3
Buy a Purple K extinguisher. You can find them on... May 9 2020, 12:56 PM
ndfrigi
Buy a Purple K extinguisher. You can find them o... May 9 2020, 01:18 PM
914Toy
Buy a Purple K extinguisher. You can find them on... May 9 2020, 02:18 PM
Coondog
[quote name='Coondog' post='2673678' date='Dec 13... May 9 2020, 02:32 PM
914Toy
[quote name='Coondog' post='2673678' date='Dec 1... May 9 2020, 08:19 PM
Big Len Based on Coondog's recommendation, that's ... Dec 13 2018, 07:47 PM
Coondog Here is my current set up Purple K 20 B-C. Halotro... May 9 2020, 02:28 PM
bkrantz For many years I was an SCCA corner worker, and I ... May 9 2020, 08:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 01:31 PM |
