School me on trans axles, Boxster 6 v Cayman 6 |
HalfMoon |
Dec 17 2018, 09:31 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Well, I've decided the time has come to change my sbc powered teener to a better trans axle but in doing some research, I'm not clear on a few things...I've pretty much narrowed it down to either a Boxster or Cayman 6 speed.
While I know there are gads and gads of alternatives many of which the reader will no doubt recommend, for a variety of reason I'd rather we stay on point the original post. And while your guess's are fun to read, first hand experience is far more valuable. First, I gather the Boxster S and Cayman Six speeds are essentially the same the Cayman having a higher gear set ratio. True? False? Renegade Hybrids stated the adapter they make for the Boxster is for the S six speed because their opinion is the five speed isn't robust enough to take the torque developed by a v-8. True? False? When it comes to the Boxster and the Cayman five speed, I've heard the Passat five speed is essentially the same but quite a bit less expensive. True? False? Would a sbc developing 400hp with something like 350 ft Lbs of torque have the ability to grenade the Boxster/Cayman (or Audi if true) five speed box if driven responsibly with frequent track days? Yes, no? And forgive this last question, the Audi FWD 01E trans axle six speed, what models used this trans axle and would it, could it, be used in the above noted spec engine without grenading? Thank you in advance for your input and first hand experience. |
Mike Bellis |
Dec 17 2018, 10:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Boxster & Cayman are essentially the same transmission with like a 0.01 difference in final ratio. Different model number too.
There are two styles on Boxster 6 speed. One has the traditional "Audi" shape bellhousing and one is round. The O1E has the traditional Audi style shape. The O1E was never imported as a FWD transmission. Or the numbers are so low you will never find one in a car. They can be had cheap from Ebay.UK I got my Boxster 6 speed (GETRAG) from the UK for under $1k shipped. If I were you, look for an O1E or a TDI tranny from the UK. The TDI has taller gearing for the diesel motor. This would work better than the O1E or my GETRAG 6 speed. I forget the exact year the round bellhousing is from but you would be buying a Porsche tranny and paying the price for it. The Passat uses an Audi FWD tranny and so do many of the European TDI vehicles from VW, Audi, Scoda, etc. A Passat tranny can be had for under $400 and is almost identical to the Boxster 5 speed. Since is is the traditional Audi shape, I bet it could even be fit to a 944 motor. Thay all use the same or similar hydraulic slave cylinder. I use a Passat slave on both the 5 & 6 speed. Two reasons: Cheaper than the Porsche unit and 034 Motorsport sells a 3AN fitting adapter for it. When I swap trannies, I leave the slave in the car and swap it without bleeding. |
HalfMoon |
Dec 17 2018, 10:38 PM
Boxster & Cayman are essentially the same transmission with like a 0.01 difference in final ratio. Different model number too. There are two styles on Boxster 6 speed. One has the traditional "Audi" shape bellhousing and one is round. The O1E has the traditional Audi style shape. The O1E was never imported as a FWD transmission. Or the numbers are so low you will never find one in a car. They can be had cheap from Ebay.UK I got my Boxster 6 speed (GETRAG) from the UK for under $1k shipped. If I were you, look for an O1E or a TDI tranny from the UK. The TDI has taller gearing for the diesel motor. This would work better than the O1E or my GETRAG 6 speed. I forget the exact year the round bellhousing is from but you would be buying a Porsche tranny and paying the price for it. The Passat uses an Audi FWD tranny and so do many of the European TDI vehicles from VW, Audi, Scoda, etc. A Passat tranny can be had for under $400 and is almost identical to the Boxster 5 speed. Since is is the traditional Audi shape, I bet it could even be fit to a 944 motor. Thay all use the same or similar hydraulic slave cylinder. I use a Passat slave on both the 5 & 6 speed. Two reasons: Cheaper than the Porsche unit and 034 Motorsport sells a 3AN fitting adapter for it. When I swap trannies, I leave the slave in the car and swap it without bleeding. You sir, are awesome :-) Thank you so much for the valuable data! |
Lo-Fi Version | Time is now: 1st June 2024 - 08:34 AM |
